| Ferg |
Aug 24 2009, 11:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Dwell is 49 at idle, jumps to 50 just off idle and goes all the way to 53 at full advance (3500 rpms), advance and retard hoses were hooked up for dwell check, I know to unhook them for timing. Is that right, or do I need to unhook them for dwell, as well.
Possible dizzy advacing plate issue? Car has a miss at 3kish, I'm trying to squash. Stock 74 2.0 djet. timing is set at 29. |
| brant |
Aug 24 2009, 11:45 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,281 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
thats weird
I'll let the experts jump in but the dwell is measuring the point gap that shouldn't change with rpm (maybe a wobbly shaft?) the gap shouldn't change with timing... it should always be the same gap. I'd pop the cap and check the gap with a feeler guage while at the peak of the lobe... may need to roll the car forward or back to find peak. hmmm.... |
| Ferg |
Aug 24 2009, 11:56 PM
Yes, strange indeed.
I did check gap again, seems spot on, and still get a solid 49 while idling. Just jumps to 53 when I take it to 3500. |
| SLITS |
Aug 25 2009, 08:40 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The points are a spring. If you activate the spring in enough cycles per minute you can get spring bounce just like a valve spring (kinda like floating the valves) in which the dwell would change with RPM.
Try a new set of points for fun or just get an electronic module (I prefer Led trigger, but your experience may be different) that would not be subject to dwell changes. Ferg, you are WAY to anal. That's 3 cups of coffee thoughts. |
| ME733 |
Aug 25 2009, 08:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
The points are a spring. If you activate the spring in enough cycles per minute you can get spring bounce just like a valve spring (kinda like floating the valves) in which the dwell would change with RPM. Try a new set of points for fun or just get an electronic module (I prefer Led trigger, but your experience may be different) that would not be subject to dwell changes. Ferg, you are WAY to anal. That's 3 cups of coffee thoughts. (IMG:style_emoticons/default/agree.gif) And as suggested ,the shaft in the distributor....may have some wobble, due to it,s age and it,s old and all the perfect is gone!!....bouncing points , at 3000 rpm,s...guess what they are doing at even higher rpm,s.!!...this is probably the cause of the misfires when driving....replace the points,and condenser, with a new bosch set.....if the problems persist/ dwell changes/...it,s probably time for a NEW distributor...and trigger it with led...put these problems behind you as it ain't likely to heal itself....good luck. |
| jaxdream |
Aug 25 2009, 09:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I've heard of circle track racers that run a Mallory dual point dizzy to solder a second points arm spring on top of the primary arm to help eliminate point bounce , supposedly works very well.
Jaxdream |
| Ferg |
Aug 25 2009, 09:10 AM
These are brand new points (second set) and new condensor. I'll try swapping them out again with my spare set, but both are new.
I'll wiggle the shaft (he he) tonight as well. I did it once before and didn't remember any slop. |
| Cap'n Krusty |
Aug 25 2009, 09:22 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Worn out breaker plate. The condenser, BTW, cannot and does not have anything to do with dwell.
The Cap'n |
| Ferg |
Aug 25 2009, 09:28 AM
Worn out breaker plate. The condenser, BTW, cannot and does not have anything to do with dwell. The Cap'n Thanks Cap'n, just got off the phone with my local wrench and that was what he said as well. Are they still available? Or do I need to start looking for a used dizzy Also, in the short term should I lower the dwell to 45ish, so when it jumps it stays in range, will that help? |
| JoeSharp |
Aug 25 2009, 09:41 AM
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Hey Mikie, put some 30 weight on all the stuff below the points and grease the points. The oil is to see if it helps with the woble of the shaft and the grease is to keep the points from bouncing. If the shaft wobles less then get a new dist. Weather or not the points are bouncing replace them with something electronic.
| McMark |
Aug 25 2009, 03:25 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Cap'n, what wears out on the breaker plate? Does the advance plate become loose?
| ME733 |
Aug 25 2009, 06:45 PM
Worn out breaker plate. The condenser, BTW, cannot and does not have anything to do with dwell. The Cap'n (IMG:style_emoticons/default/blink.gif) WHEN he replaces the points,...don't you think a new condenser is in order..?...the condenser CAN have something to do with misfiring.Lets suggest doing it all right..ONE #@&%**# TIME. (IMG:style_emoticons/default/popcorn[1].gif) |
| Ferg |
Aug 25 2009, 09:36 PM
reset the dwell to 45 tonight, and retimed it to 28 degrees.
Runs a little happier, initial throttle tip in is smother and my miss at 3kish is less pronounced. oiled as joe suggested, and more dizzy grease on the shaft. dwell is still jumping to 49 at full advance. that's a bit much. no slop that I can tell in the shaft, gotta be the plates. Found a crane optical (thanks slits) so that will be going in this weekend. Ferg |
Lo-Fi Version | Time is now: 21st October 2026 - 02:25 AM |
