> Can These Bushings Be Replaced?
kconway
post Sep 22 2009, 05:16 PM
First off, do these bushings look like they need to be replaced? They are pretty tight as the linkage seems to bind, not sure if thats good or bad.
Assuming that they do need to be replaced, how do you get them out? Do you drive the center pin out?
Kev
Replies(1 - 4)
ghuff
post Sep 22 2009, 05:19 PM
This is certainly not what I expected down here.
QUOTE(kconway @ Sep 22 2009, 03:16 PM) *
Kev
THey make brass and poly replacements.
The previous owner of my car used the poly version and built a little retaining cage and drilled a hole with a self tapping metal screw holding the cage on to the unit to keep the bushings in.
SLITS
post Sep 22 2009, 05:20 PM
"This Utah shit is HARSH!"
They can be replaced Kevin ... using a socket on one side that is the diameter of the aluminum housing and a punch to drive out the pin on the other.
BUT
Why would you want to ... they are not deteroriated and their stiffness in rotation has no effect on how the car shifts. Tight is GOOD as in other things in life.
They won't fall out. The pin can only fall out if someone dicked with it and made it smaller to avoid the interference fit.
kconway
post Sep 22 2009, 05:21 PM
QUOTE(SLITS @ Sep 22 2009, 03:20 PM) *
BUT
Why would you want to ... they are not deteroriated and their stiffness in rotation has no effect on how the car shifts. Tight is GUTE as in other things in life.
Okay, thanks Ron. Thats what I needed to know.
Kev (IMG:style_emoticons/default/beerchug.gif)
McMark
post Oct 2 2009, 07:59 PM
914 Freak!
Here's what slop looks like.
https://www.youtube.com/watch?v=rjRuQAp1DYA
- Lo-Fi Version Time is now: 7th December 2025 - 08:19 PM
