CYL head temp sensor, these values look right ? |
underthetire |
Sep 24 2009, 08:07 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Broke my good Fluke meter, had to use my backup meter. Still a good meter, with data logging to a pc even, but do these values look correct ?
47 deg measured with a K thermocouple = 3.6K ohm 85 deg 1.9 K ohm 213 deg .218K ohm (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
Dave_Darling |
Sep 25 2009, 01:05 AM
Close enough for gov't work. Or for our fuel injection.
According to http://members.rennlist.com/pbanders/DJetParts.htm the sensor should read: > 2K ohms at 68 deg. F for all but 1973 2.0 L, > 1.2 K ohms for 1973 2.0L Hotter temps will read lower, colder temps higher. By ~350F or so, the resistance should be about 100 ohms or less. --DD |
Lo-Fi Version | Time is now: 16th June 2024 - 02:03 PM |
