| biosurfer1 |
Feb 20 2008, 06:11 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I have been having a strange problem and am not really sure where to start diagnosing.
After the car is up to operating temp, whenever I shift to neutral, if the RPM's are above 2k, the car idles at about 1800rpm until I start again. If I keep the car in gear and wait until the RPM's are below ~1500, then it drops down to about 800rpm, and idles as normal. Everything else seems to be fine with the car's mechanical, just this one weird glitch.... Is it the decel valve? Something else? |
| Rand |
Feb 21 2008, 04:57 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
If it turns out to not be the decel valve...
Check out the advance plates and the vacuum canister on the distributor. My car was doing this at one point, and the plates were gunky. Refurbed the dizzy, clean, lube, and replaced the vacuum unit (which was leaky) and it cured my problem. (Don't know which year/motor you have - my 75 2.0 used vacuum retard at idle on the dizzy, yours may not.) But the dizzy might need some maintenance anyway. |
biosurfer1 Strange idle after decel.? Feb 20 2008, 06:11 PM
Demick Typical symptom of a bad decel valve. Will mainta... Feb 20 2008, 08:27 PM
biosurfer1 I don't doubt you Demick, but if that were tru... Feb 20 2008, 10:58 PM
Demick Mostly for emissions. Feb 20 2008, 11:43 PM
Thack Because you don't want to drop to idle rpm aft... Feb 21 2008, 04:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 11:39 PM |
