| JRust |
Feb 24 2008, 10:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I bought nice set of SS HE along with a dual tip Triad Muffler a while back. I got them from John Kelly (Ghia Specialties). He had them on a big 4 also. Just wanted some input as to wether these will be sufficient? I would like to retain my heat if possible. The carbs are 48 weber's I believe. Not sure on the jets or anything yet. Bought the engine from Craig at Camp914. The only problem is we don't have any build info on it. I figure to put it in & see how it feels/runs.
This may be a dumb question but it was built off a GC 2.0 engine. Are the spark plugs different when you build a big 4 or do you still use the stock plug & gap? Obviously this is a new arena for me with the big 4. Any advice is much appreciated. I am hoping to put it in early next month. Just getting to prepping/fixing my engine bay while it is empty (IMG:style_emoticons/default/blink.gif) |
Phoenix 914-6GT As to your exhaust it should be great. As to the o... Feb 24 2008, 10:19 PM
jd74914 They should work, but will really choke the engine... Feb 24 2008, 10:32 PM
craig downs The stock exhaust so way to small and your looking... Feb 24 2008, 10:59 PM
Phoenix 914-6GT If it is a triad it is not stock. The SSEs are per... Feb 24 2008, 11:02 PM
jd74914
If it is a triad it is not stock. The SSEs are pe... Feb 24 2008, 11:09 PM
Phoenix 914-6GT Well sh!t, I guess I just don't know what ... Feb 24 2008, 11:33 PM
Heeltoe914 Go headers, and try running a NGK BP5es plug. afte... Feb 25 2008, 12:46 AM
Jake Raby The TIV is all about exhaust!! This engine... Feb 25 2008, 05:08 AM
JRust
The TIV is all about exhaust!! This engin... Feb 25 2008, 10:31 PM
JRust The heat is not all that critical. It would be nic... Feb 25 2008, 09:24 AM
Brando Go with the Tangerine header. He makes one with he... Feb 25 2008, 04:10 PM
Racer Chris 40s are small for a 2.4L. Look at the primary ven... Feb 26 2008, 06:01 AM
JRust
40s are small for a 2.4L. Look at the primary ve... Feb 26 2008, 10:31 AM
Jake Raby Yep, 40s are too small..
You need a pair of 44s fo... Feb 26 2008, 08:21 AM
JRust
You need a pair of 44s f... Feb 26 2008, 10:39 AM
Phoenix 914-6GT There are a few people that have 44s that want 40s... Feb 26 2008, 10:43 AM
JmuRiz Would the Dell 45s be the best carb for this size ... Feb 26 2008, 10:58 AM
Jake Raby
Would the Dell 45s be the best carb for this size... Feb 26 2008, 12:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th June 2026 - 04:31 AM |
