> 4 speed tranny stuff for the V8 and high HP /6 crowd, Pictures
Dr Evil
post Feb 25 2008, 05:53 PM
Send me your transmission!
Here is the latest gearbox I am building for someone. It is an F-N-X-HBf box and I wanted to show how easy it is to lock out 1st in a 4 speed box. I have heard that there are people that charge a chunk of change to do the same thing....I think that is wrong as it is way easy. All you need is a rear gasket, tubing cutter and a section of 3/8" copper tubing (1/2" shown as I bought the wrong size).
Here is the FNXHBf stack (Ooo, purdy).
Here is the shift rod end for 1st that needs the sleeve to lock it out. I removed 1st gear completely other than the gear on the input shaft as you need it for reverse.
And here is the section of ~2" copper tubing. You need to keep the slider for revers. It looks like the sleeve will hit the slider, but it is just the angle of the pic. Attached Image
Andyrew
post Feb 26 2008, 12:37 AM
Spooling.... Please wait
So based on this info, with a 26" tire, and a 7k rev limit... we could hit 60 in F gear? on a stock 901?
Dang, I am really short shifting.... Think of the 0-60 times... mid 3's!!
Dr Evil
post Feb 26 2008, 08:24 AM
QUOTE(Andyrew @ Feb 26 2008, 01:37 AM) *
25" wheels. With 26" wheels you will hit 70 faster, if you have the torque to pull it off.
Dr Evil   4 speed tranny stuff for the V8 and high HP /6 crowd   Feb 25 2008, 05:53 PM
Dr Evil   This could easily be done by anyone with limited e...   Feb 25 2008, 05:54 PM
So.Cal.914   Cool Evil... :)   Feb 25 2008, 06:00 PM
dwillouby   I did the same thing to mine. Also installed an H ...   Feb 25 2008, 06:11 PM
Trevorg7   Is that the one we did at my place last month or a...   Feb 25 2008, 06:12 PM
Dr Evil   Nope, this is a different box.   Feb 25 2008, 06:23 PM
BIGKAT_83   I did the same thing to mine. Also installed an H...   Feb 25 2008, 06:30 PM
Dr Evil   I was referring to the lockout modification as bei...   Feb 25 2008, 06:43 PM
Dr Evil   When you guys say that you flipped other gears, wh...   Feb 25 2008, 06:44 PM
marks914   When Brad Mayeur did mine, he said it was no big d...   Feb 25 2008, 07:35 PM
Dr Evil   That seems like a tight grouping in the upper gear...   Feb 25 2008, 08:09 PM
Dr Evil   That seems like a tight grouping in the upper gea...   Feb 26 2008, 08:47 AM
michaelt55   Looks good to me Mike.... thanks.. Michael ...   Feb 26 2008, 09:04 AM
rick 918-S   What tire size are you using in your charts? 245/5...   Feb 25 2008, 09:22 PM
Dr Evil   Tire diameter of 25"   Feb 25 2008, 09:29 PM
Andyrew   So based on this info, with a 26" tire, and a...   Feb 26 2008, 12:37 AM
Dr Evil   So based on this info, with a 26" tire, and ...   Feb 26 2008, 08:24 AM
Andyrew   So based on this info, with a 26" tire, and...   Feb 26 2008, 07:53 PM
Dr. Roger   I think mine is a (1st gear delete) tight 1st, sec...   Feb 26 2008, 02:38 AM
Dr Evil   I think mine is a (1st gear delete) tight 1st, se...   Feb 26 2008, 08:23 AM
slothness   Hey Doc, are you still rebuilding 1st gear lock ou...   Feb 27 2012, 02:52 PM
type47fan   . . . use one of these from a '65-'66 911/...   Feb 27 2012, 03:21 PM
jimkelly   who has best price on this knob??? found this... ...   Sep 25 2015, 01:10 PM
slothness   :trophy: WANT   Feb 27 2012, 03:22 PM
Dr Evil   Never an issue. Toss 1st gear, keep the race as a ...   Feb 27 2012, 03:42 PM
matthepcat   For those of us running a locked out first gear an...   Feb 27 2012, 03:48 PM
Dr Evil   Very easy. No special nothing needed.   Feb 27 2012, 03:57 PM
slothness   Thats what I hoped, I'll give it a try. Thanks...   Feb 27 2012, 05:36 PM
Dr Evil   Thanks for the endorsement, Mark :)   Feb 27 2012, 09:05 PM
- Lo-Fi Version Time is now: 12th August 2026 - 04:24 AM
