> 2.4 lt big four Exhaust ?'s
JRust
post Feb 24 2008, 10:12 PM
I bought nice set of SS HE along with a dual tip Triad Muffler a while back. I got them from John Kelly (Ghia Specialties). He had them on a big 4 also. Just wanted some input as to wether these will be sufficient? I would like to retain my heat if possible. The carbs are 48 weber's I believe. Not sure on the jets or anything yet. Bought the engine from Craig at Camp914. The only problem is we don't have any build info on it. I figure to put it in & see how it feels/runs.
This may be a dumb question but it was built off a GC 2.0 engine. Are the spark plugs different when you build a big 4 or do you still use the stock plug & gap? Obviously this is a new arena for me with the big 4. Any advice is much appreciated. I am hoping to put it in early next month. Just getting to prepping/fixing my engine bay while it is empty (IMG:style_emoticons/default/blink.gif)
ChrisFoley
post Feb 26 2008, 06:01 AM
I am Tangerine Racing
40s are small for a 2.4L. Look at the primary venturi size. The number is usually cast onto the surface near the top.
JRust
post Feb 26 2008, 10:31 AM
QUOTE(Racer Chris @ Feb 26 2008, 04:01 AM) *
Will do! I'll post it when I get a chance. (IMG:style_emoticons/default/biggrin.gif)
JRust   2.4 lt big four Exhaust ?'s   Feb 24 2008, 10:12 PM
Phoenix 914-6GT   As to your exhaust it should be great. As to the o...   Feb 24 2008, 10:19 PM
jd74914   They should work, but will really choke the engine...   Feb 24 2008, 10:32 PM
craig downs   The stock exhaust so way to small and your looking...   Feb 24 2008, 10:59 PM
Phoenix 914-6GT   If it is a triad it is not stock. The SSEs are per...   Feb 24 2008, 11:02 PM
jd74914   If it is a triad it is not stock. The SSEs are pe...   Feb 24 2008, 11:09 PM
Phoenix 914-6GT   Well sh!t, I guess I just don't know what ...   Feb 24 2008, 11:33 PM
Heeltoe914   Go headers, and try running a NGK BP5es plug. afte...   Feb 25 2008, 12:46 AM
Jake Raby   The TIV is all about exhaust!! This engine...   Feb 25 2008, 05:08 AM
JRust   The TIV is all about exhaust!! This engin...   Feb 25 2008, 10:31 PM
JRust   The heat is not all that critical. It would be nic...   Feb 25 2008, 09:24 AM
Brando   Go with the Tangerine header. He makes one with he...   Feb 25 2008, 04:10 PM
Racer Chris   40s are small for a 2.4L. Look at the primary ven...   Feb 26 2008, 06:01 AM
JRust   40s are small for a 2.4L. Look at the primary ve...   Feb 26 2008, 10:31 AM
Jake Raby   Yep, 40s are too small.. You need a pair of 44s fo...   Feb 26 2008, 08:21 AM
JRust   Yep, 40s are too small.. You need a pair of 44s f...   Feb 26 2008, 10:39 AM
Phoenix 914-6GT   There are a few people that have 44s that want 40s...   Feb 26 2008, 10:43 AM
JmuRiz   Would the Dell 45s be the best carb for this size ...   Feb 26 2008, 10:58 AM
Jake Raby   Would the Dell 45s be the best carb for this size...   Feb 26 2008, 12:43 PM
- Lo-Fi Version Time is now: 27th June 2026 - 04:30 AM
