| mikeyboy_85 |
Mar 1 2008, 02:13 AM
Member ![]() ![]() Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
I have just had the transmission and all the bushes replaced about 5000 miles ago and driving along today and it has decided that 4th and 5th arn't there, when i go to shift into 4th i keep selecting 2nd, Does anyone know what could of gone wrong? The gears feel a bit sloppy too . . .
thanks michael |
| KaptKaos |
Mar 1 2008, 10:02 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Are we sure its a side shift?
mikeyboy_85 HELP - Car won't go into 4th and 5th gears Mar 1 2008, 02:13 AM
Dr. Roger Check bolt #1 on this Pelican Parts diagram.
AKA ... Mar 1 2008, 02:31 AM
ejm :agree: Also check the cone screws #23 + 26 Mar 1 2008, 05:49 AM
pete914 cone set screw in the back may be loose
or, as sta... Mar 1 2008, 11:09 AM
So.Cal.914
:confused:
A w... Mar 1 2008, 01:06 PM
geniusanthony if it is a loose bolt somewhere. which it probably... Mar 1 2008, 01:02 PM
Pakis Make sure bolt #7 on that same diagram is tight an... Mar 1 2008, 02:37 PM
Dave_Darling Another possibility is that the clutch tube inside... Mar 1 2008, 06:49 PM
mikeyboy_85 hey, thanks for all the replies, its a 72mdl but h... Mar 1 2008, 07:53 PM
degreeoff Dude...if it is one of the above listed things the... Mar 1 2008, 08:12 PM
mikeyboy_85 ok i tried the adjustment at the bottom of the gea... Mar 1 2008, 09:29 PM
Cevan There is a rubber boot (#29) over the shift rod wh... Mar 1 2008, 09:55 PM
mikeyboy_85 but its not just a matter of tightening is it ?? w... Mar 1 2008, 10:03 PM
Dave_Darling The cone screws give you no adjustment; they simpl... Mar 2 2008, 12:02 AM
mikeyboy_85 jsut got undercar and the cone screw was so loose ... Mar 2 2008, 12:38 AM
racunniff
jsut got undercar and the cone screw was so loose... Mar 2 2008, 12:42 AM
mikeyboy_85 just as i was about to give up, I got it! perf... Mar 2 2008, 02:37 AM
rhodyguy now that you have the linkage adjusted, source new... Mar 2 2008, 08:02 AM
degreeoff :Qarl: :cheer: :headbanger: way to go man...easy... Mar 2 2008, 08:48 AM
zx-niner Timely thread. I just experienced the same proble... Mar 2 2008, 12:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th August 2026 - 01:21 PM |
