> HELP - Car won't go into 4th and 5th gears
mikeyboy_85
post Mar 1 2008, 02:13 AM
I have just had the transmission and all the bushes replaced about 5000 miles ago and driving along today and it has decided that 4th and 5th arn't there, when i go to shift into 4th i keep selecting 2nd, Does anyone know what could of gone wrong? The gears feel a bit sloppy too . . .
thanks michael
KaptKaos
post Mar 1 2008, 10:02 AM
Family
Are we sure its a side shift?
pete914
post Mar 1 2008, 11:09 AM
cone set screw in the back may be loose
or, as stated above your front shift linkage pinch bolt loosened...
mikeyboy_85   HELP - Car won't go into 4th and 5th gears   Mar 1 2008, 02:13 AM
Dr. Roger   Check bolt #1 on this Pelican Parts diagram. AKA ...   Mar 1 2008, 02:31 AM
ejm   :agree: Also check the cone screws #23 + 26   Mar 1 2008, 05:49 AM
KaptKaos   Are we sure its a side shift?   Mar 1 2008, 10:02 AM
pete914   cone set screw in the back may be loose or, as sta...   Mar 1 2008, 11:09 AM
So.Cal.914   Are we sure its a side shift? :confused: A w...   Mar 1 2008, 01:06 PM
geniusanthony   if it is a loose bolt somewhere. which it probably...   Mar 1 2008, 01:02 PM
Pakis   Make sure bolt #7 on that same diagram is tight an...   Mar 1 2008, 02:37 PM
Dave_Darling   Another possibility is that the clutch tube inside...   Mar 1 2008, 06:49 PM
mikeyboy_85   hey, thanks for all the replies, its a 72mdl but h...   Mar 1 2008, 07:53 PM
degreeoff   Dude...if it is one of the above listed things the...   Mar 1 2008, 08:12 PM
mikeyboy_85   ok i tried the adjustment at the bottom of the gea...   Mar 1 2008, 09:29 PM
Cevan   There is a rubber boot (#29) over the shift rod wh...   Mar 1 2008, 09:55 PM
mikeyboy_85   but its not just a matter of tightening is it ?? w...   Mar 1 2008, 10:03 PM
Dave_Darling   The cone screws give you no adjustment; they simpl...   Mar 2 2008, 12:02 AM
mikeyboy_85   jsut got undercar and the cone screw was so loose ...   Mar 2 2008, 12:38 AM
racunniff   jsut got undercar and the cone screw was so loose...   Mar 2 2008, 12:42 AM
mikeyboy_85   just as i was about to give up, I got it! perf...   Mar 2 2008, 02:37 AM
rhodyguy   now that you have the linkage adjusted, source new...   Mar 2 2008, 08:02 AM
degreeoff   :Qarl: :cheer: :headbanger: way to go man...easy...   Mar 2 2008, 08:48 AM
zx-niner   Timely thread. I just experienced the same proble...   Mar 2 2008, 12:21 PM
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: Jack Standz
- Lo-Fi Version Time is now: 20th August 2026 - 01:20 PM
