> HELP - Car won't go into 4th and 5th gears
mikeyboy_85
post Mar 1 2008, 02:13 AM
I have just had the transmission and all the bushes replaced about 5000 miles ago and driving along today and it has decided that 4th and 5th arn't there, when i go to shift into 4th i keep selecting 2nd, Does anyone know what could of gone wrong? The gears feel a bit sloppy too . . .
thanks michael
Pakis
post Mar 1 2008, 02:37 PM
Make sure bolt #7 on that same diagram is tight and most importantly installed in the correct position. When installed in the wrong direction the threaded end comes in contact with other parts in the center channel. You can see the scars it this is happening. I believe that with a stock shifter that it will still work but if you have a short shift kit you can't get enough leverage to move it into gear. Of course I have never placed that bolt in the wrong way, more than once that is.
mikeyboy_85   HELP - Car won't go into 4th and 5th gears   Mar 1 2008, 02:13 AM
Dr. Roger   Check bolt #1 on this Pelican Parts diagram. AKA ...   Mar 1 2008, 02:31 AM
ejm   :agree: Also check the cone screws #23 + 26   Mar 1 2008, 05:49 AM
KaptKaos   Are we sure its a side shift?   Mar 1 2008, 10:02 AM
pete914   cone set screw in the back may be loose or, as sta...   Mar 1 2008, 11:09 AM
So.Cal.914   Are we sure its a side shift? :confused: A w...   Mar 1 2008, 01:06 PM
geniusanthony   if it is a loose bolt somewhere. which it probably...   Mar 1 2008, 01:02 PM
Pakis   Make sure bolt #7 on that same diagram is tight an...   Mar 1 2008, 02:37 PM
Dave_Darling   Another possibility is that the clutch tube inside...   Mar 1 2008, 06:49 PM
mikeyboy_85   hey, thanks for all the replies, its a 72mdl but h...   Mar 1 2008, 07:53 PM
degreeoff   Dude...if it is one of the above listed things the...   Mar 1 2008, 08:12 PM
mikeyboy_85   ok i tried the adjustment at the bottom of the gea...   Mar 1 2008, 09:29 PM
Cevan   There is a rubber boot (#29) over the shift rod wh...   Mar 1 2008, 09:55 PM
mikeyboy_85   but its not just a matter of tightening is it ?? w...   Mar 1 2008, 10:03 PM
Dave_Darling   The cone screws give you no adjustment; they simpl...   Mar 2 2008, 12:02 AM
mikeyboy_85   jsut got undercar and the cone screw was so loose ...   Mar 2 2008, 12:38 AM
racunniff   jsut got undercar and the cone screw was so loose...   Mar 2 2008, 12:42 AM
mikeyboy_85   just as i was about to give up, I got it! perf...   Mar 2 2008, 02:37 AM
rhodyguy   now that you have the linkage adjusted, source new...   Mar 2 2008, 08:02 AM
degreeoff   :Qarl: :cheer: :headbanger: way to go man...easy...   Mar 2 2008, 08:48 AM
zx-niner   Timely thread. I just experienced the same proble...   Mar 2 2008, 12:21 PM
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: Jack Standz
- Lo-Fi Version Time is now: 20th August 2026 - 01:22 PM
