| mikeyboy_85 |
Mar 1 2008, 02:13 AM
Member ![]() ![]() Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
I have just had the transmission and all the bushes replaced about 5000 miles ago and driving along today and it has decided that 4th and 5th arn't there, when i go to shift into 4th i keep selecting 2nd, Does anyone know what could of gone wrong? The gears feel a bit sloppy too . . .
thanks michael |
| degreeoff |
Mar 1 2008, 08:12 PM
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Dude...if it is one of the above listed things then do it yourself....check the bolt down in the tunnel behind the shifter lever and the set screws it is not that tough and you should be able to get it with a lil help from the Haynes manual. You own a teener so learn how to fix it! it is monkey simple man.......
mikeyboy_85 HELP - Car won't go into 4th and 5th gears Mar 1 2008, 02:13 AM
Dr. Roger Check bolt #1 on this Pelican Parts diagram.
AKA ... Mar 1 2008, 02:31 AM
ejm :agree: Also check the cone screws #23 + 26 Mar 1 2008, 05:49 AM
KaptKaos Are we sure its a side shift? Mar 1 2008, 10:02 AM
pete914 cone set screw in the back may be loose
or, as sta... Mar 1 2008, 11:09 AM
So.Cal.914
:confused:
A w... Mar 1 2008, 01:06 PM
geniusanthony if it is a loose bolt somewhere. which it probably... Mar 1 2008, 01:02 PM
Pakis Make sure bolt #7 on that same diagram is tight an... Mar 1 2008, 02:37 PM
Dave_Darling Another possibility is that the clutch tube inside... Mar 1 2008, 06:49 PM
mikeyboy_85 hey, thanks for all the replies, its a 72mdl but h... Mar 1 2008, 07:53 PM
mikeyboy_85 ok i tried the adjustment at the bottom of the gea... Mar 1 2008, 09:29 PM
Cevan There is a rubber boot (#29) over the shift rod wh... Mar 1 2008, 09:55 PM
mikeyboy_85 but its not just a matter of tightening is it ?? w... Mar 1 2008, 10:03 PM
Dave_Darling The cone screws give you no adjustment; they simpl... Mar 2 2008, 12:02 AM
mikeyboy_85 jsut got undercar and the cone screw was so loose ... Mar 2 2008, 12:38 AM
racunniff
jsut got undercar and the cone screw was so loose... Mar 2 2008, 12:42 AM
mikeyboy_85 just as i was about to give up, I got it! perf... Mar 2 2008, 02:37 AM
rhodyguy now that you have the linkage adjusted, source new... Mar 2 2008, 08:02 AM
degreeoff :Qarl: :cheer: :headbanger: way to go man...easy... Mar 2 2008, 08:48 AM
zx-niner Timely thread. I just experienced the same proble... Mar 2 2008, 12:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th August 2026 - 01:23 PM |
