| mikeyboy_85 |
Mar 1 2008, 02:13 AM
Member ![]() ![]() Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
I have just had the transmission and all the bushes replaced about 5000 miles ago and driving along today and it has decided that 4th and 5th arn't there, when i go to shift into 4th i keep selecting 2nd, Does anyone know what could of gone wrong? The gears feel a bit sloppy too . . .
thanks michael |
| Cevan |
Mar 1 2008, 09:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
There is a rubber boot (#29) over the shift rod where it exists the firewall under the car. Pull the boot away from the firewall and you'll see where the rear shift rod (#27) mates with the front shift rod (#30). Tighten the cone screw with a 4 mm allen wrench.
The other cone screw is accessed by removing the black plastic cover (#22). There is a band clamp that holds it in place. Also a 4mm allen wrench. These screws can be replaced if they are worn. Pelican has them here. |
mikeyboy_85 HELP - Car won't go into 4th and 5th gears Mar 1 2008, 02:13 AM
Dr. Roger Check bolt #1 on this Pelican Parts diagram.
AKA ... Mar 1 2008, 02:31 AM
ejm :agree: Also check the cone screws #23 + 26 Mar 1 2008, 05:49 AM
KaptKaos Are we sure its a side shift? Mar 1 2008, 10:02 AM
pete914 cone set screw in the back may be loose
or, as sta... Mar 1 2008, 11:09 AM
So.Cal.914
:confused:
A w... Mar 1 2008, 01:06 PM
geniusanthony if it is a loose bolt somewhere. which it probably... Mar 1 2008, 01:02 PM
Pakis Make sure bolt #7 on that same diagram is tight an... Mar 1 2008, 02:37 PM
Dave_Darling Another possibility is that the clutch tube inside... Mar 1 2008, 06:49 PM
mikeyboy_85 hey, thanks for all the replies, its a 72mdl but h... Mar 1 2008, 07:53 PM
degreeoff Dude...if it is one of the above listed things the... Mar 1 2008, 08:12 PM
mikeyboy_85 ok i tried the adjustment at the bottom of the gea... Mar 1 2008, 09:29 PM
mikeyboy_85 but its not just a matter of tightening is it ?? w... Mar 1 2008, 10:03 PM
Dave_Darling The cone screws give you no adjustment; they simpl... Mar 2 2008, 12:02 AM
mikeyboy_85 jsut got undercar and the cone screw was so loose ... Mar 2 2008, 12:38 AM
racunniff
jsut got undercar and the cone screw was so loose... Mar 2 2008, 12:42 AM
mikeyboy_85 just as i was about to give up, I got it! perf... Mar 2 2008, 02:37 AM
rhodyguy now that you have the linkage adjusted, source new... Mar 2 2008, 08:02 AM
degreeoff :Qarl: :cheer: :headbanger: way to go man...easy... Mar 2 2008, 08:48 AM
zx-niner Timely thread. I just experienced the same proble... Mar 2 2008, 12:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th August 2026 - 01:22 PM |
