ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
As I continue to work on my daily driver, I am beginning to understand that some spare parts should always be handy. For example, I probably should always carry a spare throttle cable and clutch cable and their associated small parts along with a minimum set of tools. What other spare parts should I consider essential as I start to make longer weekend excurions?
RoadGlue |
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California ![]() ![]() |
AAA card's a good idea, but it's not going to help you if you break down out of cell phone range. A lot of the areas around where I live and travel are cell-dead. Plus, why would I want to sit on the side of the road for an hour+ just to have some dude in a truck man handle my car when I can likely fix the problem myself?
Here's what I carry: 1. Alternator Belt 2. Clutch Cable 3. Throttle Cable 4. Oil 5. Voltage Regulator 6. Spare ECU (yeah, I'm nuts) 7. Spare Relay(s) 8. Spare Fuses 9. Flashlight 10. Electrical Tape 11. Small tool box with as many tools as I can cram into it 12. Extra set of points and condenser in case my Pertronix unit takes a dive 13. Haynes manual I think I carry a few other things, but that's all I can think of without actually looking. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
RoadGlue |
6. Spare ECU (yeah, I'm nuts) interesting that you would carry a spare ECU but not a spare fuel pump..... I might actually be carrying a spare fuel pump. The cardboard box that I carry in the rear trunk holds many secrets! If not, I should throw my spare in the box. Thanks for the reminder! I think I am carrying a spare ECU because I wasn't totally confident about the one I had when I first started using it. Sylvie and I took the car up to Tahoe and into NV, so I just wanted all my bases covered. It's one of those things that you cannot pick up at FLAPS. I probably carry a spare MPS as well. Why not? AAA only tows you a 100 miles. When you're out in the sticks that means you're likely being towed to a shop that's going to charge you $100/hr and they won't know how to work on the car. Where are they going to get spares from? It's one thing if you're always in suburbia, but I take my car way up the coast, to the mountains, through the desert, etc. I need to be able to rely on myself when I'm out in no mans land. Can you tell I was a boy scout growing up? Love, |
Lo-Fi Version | Time is now: 12th July 2025 - 10:54 AM |
