drue |
Newbie ![]() Group: Members Posts: 11 Joined: 9-October 07 From: Indianapolis Member No.: 8,202 ![]() |
I've got a 1975 914/4 and I haven't been able to shift into first gear for quite awhile. I got under the car and tried doing it manually and was able to do it so I know first gear works. But for the life of me, I can't seem to adjust it to shift into first. Every time I try shifting into first gear, it grinds until I quit trying. And it's such a hassle to crawl under the car and shift into first at every stop light (IMG:style_emoticons/default/dry.gif) .
I've followed the suggestions in Kevin's post but I still can't seem to make it work. Has anyone else had this problem? It shifts into every other gear without any problem. |
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
yes, that or linkage adjustment. but most likely clutch.
understand that when the engine is idling and the flywheel is spinning, so is the clutch and pressure plate. if the clutch is not fully dis-engaged, the input shaft is still spinning and the gears will tend to not go into gear. another cause can be the pivot ball, which is screwed in the transaxle housing, has seen it's last days and is need of replacement. symptom of this is that you will see that the clutch fork is hitting the transaxle opening and the clutch is still not dis-engaging. |
Lo-Fi Version | Time is now: 16th June 2024 - 06:46 AM |
