computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
I pulled apart my spare 75 2ltr down to the block (didn't split the case) that I'm planning on putting in my 75 project car. I also pulled the heads. My intentions was just to clean it up, do a visual inspection on the heads and re-seal the motor. I was going to take the heads down to our local machine shop to have them cleaned and if necessary a valve job.
I'm looking for some advice on whether I should remove the pistons, have the cylinders honed and new rings installed? Is this worth doing on these type of motors...or do most just buy a cylinder and piston kit? Looking at all the kits available make me wonder whether to go with the stock 94s or a big bore kit. I see Jake sells a stock Mahle kit for $284 and the big bore kits are between 3 and 4 hundred elsewhere. I have both stock injection and weber 40s...probably go with carbs. I don't want to split the case to replace the cam. So what do you think? (you can tell from my questions, I'm not much of a mechanic...but I like doing things for myself) |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
I used one like the second link Cap'n posted. Just roll it out from around the cylinder and piston once you've cleared the rings.
Lo-Fi Version | Time is now: 16th June 2024 - 05:09 AM |
