Should I or Shouldn't I...pistons and cylinders?, Can of worms? |
computers4kids |
Mar 17 2008, 10:51 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I pulled apart my spare 75 2ltr down to the block (didn't split the case) that I'm planning on putting in my 75 project car. I also pulled the heads. My intentions was just to clean it up, do a visual inspection on the heads and re-seal the motor. I was going to take the heads down to our local machine shop to have them cleaned and if necessary a valve job.
I'm looking for some advice on whether I should remove the pistons, have the cylinders honed and new rings installed? Is this worth doing on these type of motors...or do most just buy a cylinder and piston kit? Looking at all the kits available make me wonder whether to go with the stock 94s or a big bore kit. I see Jake sells a stock Mahle kit for $284 and the big bore kits are between 3 and 4 hundred elsewhere. I have both stock injection and weber 40s...probably go with carbs. I don't want to split the case to replace the cam. So what do you think? (you can tell from my questions, I'm not much of a mechanic...but I like doing things for myself) |
Jake Raby |
Mar 18 2008, 02:16 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE Are these cheap sets as good as the stock 93 pistons in there? No, the cheap sets should be a last resort. I **really** don't like stocking or selling them, but in the 90 and 93mm bore size they are all thats available shy of a 96mm. I'd go to 96s and not look back, our KB set works very well and with some slight head work and a 9550 cam 115 BHP is easily attainable. |
Lo-Fi Version | Time is now: 16th June 2024 - 09:05 AM |
