4 piston brake calipers ..., what are my options? |
SirAndy |
Mar 22 2008, 07:12 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i'd like to go to a set of (bigger) 4 piston brake calipers on all 4 corners.
right now, i have '84 carrera hubs, rotors and calipers all around ... what are my options? what's a direct bolt on, what does require adapters? (IMG:style_emoticons/default/idea.gif) Andy |
sww914 |
Mar 22 2008, 10:00 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Boxster calipers go right on with adapters. I think that they use Carrera front rotors and Boxster rear rotors. I've been watching Boxster calipers on ebay, most are going for $500.00 to $600.00 for all 4 and the adapters are around $200.00 per axle. What kind of brake fluid are you using? Is it fresh? A bit of water in the system will reduce the boiling temperature significantly. Porterfield pads for the Boxster calipers are about $150.00 per axle. Hawk blues are about $250.00 per axle. I just went through all this for a friend a couple of days ago.
Lo-Fi Version | Time is now: 8th June 2024 - 07:00 AM |
