| Walter |
Mar 23 2008, 07:33 AM
Member ![]() ![]() Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 |
Anyone contemplating an EFI install will get into this, so I thought i show you how I've done it.
I used modern Bosch injectors which have a plastic cup at the bottom around the injector nozzle. I did file off the edge of that plastic cup so that the viton (?) O-ring can sit partly inside and against the original recess of the injector opening in the manifold. It sits very snug and well sealed or so it seems. Will need to thest this on the engine later of course. The original rubber that sits inside the bracket of the original D-jet injectors also fits the new style (3 bar efi) injectors! The fuel rail was ordered from summit and cut to length, bored and reamed the openings for the injectors (the only thing I commisioned out) and bored and tapped the ends for NPT 3/8". (IMG:http://www.keversite.nl/fotoalbum/fotos/65717.jpg) I used the original studs to also hold the fuel rail down, made small brackets which are held by bored and taped holes in the underside of the fuel rail. (IMG:http://www.keversite.nl/fotoalbum/fotos/65967.jpg) (IMG:http://www.keversite.nl/fotoalbum/fotos/65969.jpg) |
| Mark Henry |
Mar 23 2008, 10:58 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Nice! good job guys!
Walter Modern injectors in 914 2.0 manifolds Mar 23 2008, 07:33 AM
Jeff Bowlsby Nicely done! Which engine? What is the part ... Mar 23 2008, 08:22 AM
Walter
Nicely done! Which engine? What is the part... Mar 23 2008, 12:10 PM
yarin
Nicely done! Which engine? What is the par... Mar 25 2008, 08:07 PM
Jake Raby Very slick!
I have done it in a similar fashio... Mar 23 2008, 09:25 AM
toon1 your's looks nice, I like the way you supporte... Mar 23 2008, 09:57 AM
toon1 Here's another installed. ford probe 21lb/hr i... Mar 23 2008, 11:14 AM
McMark Perfect timing! I was just thinking about thi... Mar 23 2008, 12:36 PM
blitZ That's pretty slick. Are you using those inje... Mar 23 2008, 02:58 PM
Walter
That's pretty slick. Are you using those inj... Mar 25 2008, 11:56 AM
jimkelly i was leaning this way
the other jim kelly uses n... Mar 23 2008, 03:09 PM
Walter Don't know what year the TB was exactly, but i... Mar 26 2008, 02:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd December 2025 - 05:55 PM |
