> Exhaust leaks, Any tricks to getting the HEs to seat properly?
KaptKaos
post Apr 9 2008, 12:02 AM
Family
I have had my heat exchangers off and on now about 4 times, trying to make sure that they are seated and tight. I have checked the copper gasket, put in new ones and still I get popping or back firing on decel.
Tonight I pulled the driver's side and flat filed the tops of the HEs to make sure I have a good surface. Nothing drastic, just trying to make it flat and smooth.
Is there any trick to getting everything buttoned up properly?
Challe
post Apr 9 2008, 01:46 AM
Take them out, heat them as sww914 says, let them cool slowly (don't put them into water as a friend to me did (IMG:style_emoticons/default/wink.gif) ) , then install them
Heat makes the copper soft, pressure makes it hard... same thing is possible to do with the copper sealing to the oil plug if you don't have a new sealing at oilchange
EDIT: Don't reuse the crush washer, allways use a new washer at oilchange, I mentioned the method for the crush washer only as a example and what you can do when you are in some situation when you don't have a new washer (and the old one is made of solid copper), here in sweden we had regulations for asbestos since late 70s but there is of course other fillings in the market, those will not change with heat at all.
Sorry, I should have written something like this: "this procedure does not apply to the crush gaskets that have asbestos or some other filling, just the solid copper ones"
KaptKaos   Exhaust leaks   Apr 9 2008, 12:02 AM
sww914   Anneal the copper seals before you bolt up the exh...   Apr 9 2008, 12:56 AM
KaptKaos   Anneal the copper seals before you bolt up the ex...   Apr 9 2008, 01:07 AM
Challe   Take them out, heat them as sww914 says, let them ...   Apr 9 2008, 01:46 AM
porsche914gt   Check your intakes at the head. A leak there can m...   Apr 9 2008, 03:52 AM
Gint   :agree: Popping out the exhaust does not necessari...   Apr 9 2008, 07:06 AM
Garland   I used two copper gaskets, instead of one. took ca...   Apr 9 2008, 11:37 AM
Cap'n Krusty   I used two copper gaskets, instead of one. took c...   Apr 9 2008, 12:06 PM
Gint   BTW, torching an asbestos filled copper crush wash...   Apr 9 2008, 04:00 PM
Mike914   And exactly 'who in the world' suggested t...   Apr 9 2008, 11:46 PM
rjames   Do as the Cap'n says. Use one and only one cop...   Apr 9 2008, 12:35 PM
KaptKaos   Also, Gint makes a good point. How do you know th...   Apr 9 2008, 12:50 PM
jsayre914   I just installed my stailless HEs on my car last n...   Apr 9 2008, 01:05 PM
Rand   Don't worry about it jsayre914. Annealing is n...   Apr 9 2008, 01:32 PM
Gint   And exactly 'who in the world' suggested t...   Apr 10 2008, 08:55 AM
purple   Can't you just get the copper rings from jake ...   Apr 10 2008, 11:57 AM
Rand   I'm not speaking for Jake, but I'll bet a ...   Apr 10 2008, 01:17 PM
Gint   I'm not speaking for Jake, but I'll bet a...   Apr 10 2008, 05:02 PM
Rand   I'd have to re-read this whole thread, but I ...   Apr 10 2008, 05:12 PM
Challe   Cap'n is absolutly right, torching an asbestos...   Apr 10 2008, 02:58 PM
SLITS   Must be that time of the month again.   Apr 10 2008, 05:14 PM
KaptKaos   I need to redo it because I have a leak somewhere....   Apr 10 2008, 06:57 PM
tod914   "I've applied some Loctite 518 to both si...   Apr 10 2008, 07:07 PM
purple   "I've applied some Loctite 518 to both s...   Apr 11 2008, 03:56 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:11 PM
