| KaptKaos |
Apr 9 2008, 12:02 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I have had my heat exchangers off and on now about 4 times, trying to make sure that they are seated and tight. I have checked the copper gasket, put in new ones and still I get popping or back firing on decel.
Tonight I pulled the driver's side and flat filed the tops of the HEs to make sure I have a good surface. Nothing drastic, just trying to make it flat and smooth. Is there any trick to getting everything buttoned up properly? |
| tod914 |
Apr 10 2008, 07:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
"I've applied some Loctite 518 to both sides of the copper rings to help the exhaust seal. You can also use weatherstripping adhesive or anything similar. All of the sealants turn to carbon from the heat and help to provide a carbonized seal. The loctite is nice because it's so tacky but I haven't used it enough times to say it's better than anything else."
from the link. any of you guys do this? |
| purple |
Apr 11 2008, 03:56 PM
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
"I've applied some Loctite 518 to both sides of the copper rings to help the exhaust seal. You can also use weatherstripping adhesive or anything similar. All of the sealants turn to carbon from the heat and help to provide a carbonized seal. The loctite is nice because it's so tacky but I haven't used it enough times to say it's better than anything else." from the link. any of you guys do this? I used the glue you use to affix the hood logo on. it's from 3m and bonds metal to metal nicely. It helps you get everything seated and aligned without having to worry about stuff falling apart on you. |
KaptKaos Exhaust leaks Apr 9 2008, 12:02 AM
sww914 Anneal the copper seals before you bolt up the exh... Apr 9 2008, 12:56 AM
KaptKaos
Anneal the copper seals before you bolt up the ex... Apr 9 2008, 01:07 AM
Challe Take them out, heat them as sww914 says, let them ... Apr 9 2008, 01:46 AM
porsche914gt Check your intakes at the head. A leak there can m... Apr 9 2008, 03:52 AM
Gint :agree: Popping out the exhaust does not necessari... Apr 9 2008, 07:06 AM
Garland I used two copper gaskets, instead of one. took ca... Apr 9 2008, 11:37 AM
Cap'n Krusty
I used two copper gaskets, instead of one. took c... Apr 9 2008, 12:06 PM
Gint BTW, torching an asbestos filled copper crush wash... Apr 9 2008, 04:00 PM
Mike914 And exactly 'who in the world' suggested t... Apr 9 2008, 11:46 PM
rjames Do as the Cap'n says. Use one and only one cop... Apr 9 2008, 12:35 PM
KaptKaos
Also, Gint makes a good point. How do you know th... Apr 9 2008, 12:50 PM
jsayre914 I just installed my stailless HEs on my car last n... Apr 9 2008, 01:05 PM
Rand Don't worry about it jsayre914. Annealing is n... Apr 9 2008, 01:32 PM
Gint And exactly 'who in the world' suggested t... Apr 10 2008, 08:55 AM
purple Can't you just get the copper rings from jake ... Apr 10 2008, 11:57 AM
Rand I'm not speaking for Jake, but I'll bet a ... Apr 10 2008, 01:17 PM
Gint
I'm not speaking for Jake, but I'll bet a... Apr 10 2008, 05:02 PM
Rand
I'd have to re-read this whole thread, but I ... Apr 10 2008, 05:12 PM
Challe Cap'n is absolutly right, torching an asbestos... Apr 10 2008, 02:58 PM
SLITS Must be that time of the month again. Apr 10 2008, 05:14 PM
KaptKaos I need to redo it because I have a leak somewhere.... Apr 10 2008, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:41 PM |
