jesiv |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California ![]() |
Well I think my starter, solenoid or both is/are going bad. Meaning after a long… hot… ride, it just won’t start just buzzes like a solenoid. After it cools down it starts right up (about two beers). (IMG:style_emoticons/default/beer3.gif)
On my old 289 Cobra jet, I just raised the hood and whacked it with a hammer – worked every time. (IMG:style_emoticons/default/smash.gif) Should I replace the solenoid, get a new starter, or just bring more beer. If I get a new starter any recommendations on what type should I get? I have heard about more HP starters, smaller, stock, etc (IMG:style_emoticons/default/confused24.gif) Regards, James |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I can tell you why the high torque starter always works.....
Same reason the Ford solenoid works, it requires less volts to kick the plunger than a stock bosch solenoid. The Ford solenoid at $12 (say $20 max with wire, etc) is a bit cheaper though. |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I've been using a small Bosch cube relay for years and years, no problems since installing it. The solenoid trigger doesn't take a ton of current to click, but it does need voltage. The hot start relay makes sure the solenoid sees the most voltage at all times.
Lo-Fi Version | Time is now: 16th July 2025 - 04:22 PM |
