> Calling all electrical gurus........., my alternator saga continues
East coaster
post Apr 19 2008, 07:11 AM
I had a strange electrical problem with my 914 and I thought I had it resolved, but now I'm wondering.
A while back, I was driving to work and the car died. I found that the battery was dead. I removed the battery, charged it, and made it to work/home. I assumed my alternator was bad, so I ordered a new alt (alt/reg) and replaced it. I'm running 911 gauges and don't have a volt meter/amp gauge and the idiot light was not working, so I really had no indication while driving other than my stereo would crap out due to low voltage a few minutes before the engine would be affected. This gave a little warning that something was awry.
Once the alt was replaced, things seemed good for about a month or so and then it happened again. I inspected every ground and found nothing. I restricted my driving to my local hood until I figured this out and I finally thought I had.
I fired it up for a drive a few weeks back and it cranked over rapdily and started right up (as it usually does). I proceeded to back out of my driveway and started heading down the street and within 3 blocks (<1/16 mile) it began to die. I reasoned that no electrical problem can take a fully charged battery down that quickly without frying something? I could arc weld with a battery and not kill it that quick! So, I thought the battery itself is the only thing that could cause this symptom.
So, I got the battery replaced under warrantee as it checked "bad" when I returned it and it's been working OK since.
Here's my dilema (after the long winded above description!), I replaced the bulb in the idiot light and now I have a new concern. When I start the car the light is off and remains off until the rpms hit 3800 or above and then it comes on and stays on until I shut the engine off and restart. once restarted, it stays off until I hit 3800 revs. With the light on I metered the voltage and it looks good (14.2-14.4), so it seems the alt is working fine........so what's up with the damn Alt light??????
sww914
post Apr 19 2008, 03:21 PM
The alt energizer circuit runs through the alt light, When the key is on one side of the bulb is energized by the ignition switch and the other side is grounded through the not turning alt. Once the car is running the alt is energized and there is + on both sides of the light and the light goes out.
key>bulb>alt DF. If the light comes on at higher RPM's but not with the engine stopped it sounds like maybe a bad diode in the alt, but I can't remember right now.
East coaster   Calling all electrical gurus.........   Apr 19 2008, 07:11 AM
charliew   I had a battery develop a short that was intermitt...   Apr 19 2008, 08:23 AM
Spoke   When you start the car and the gen light is off, w...   Apr 19 2008, 09:15 AM
Headrage   and the idiot light was not working Not working ...   Apr 19 2008, 10:17 AM
East coaster   Idiot light was not installed when I first put the...   Apr 19 2008, 10:49 AM
Spoke   The gen light is simple and provides instant not...   Apr 19 2008, 12:07 PM
vsg914   Gen light takes it own special bulb. It is not the...   Apr 19 2008, 11:00 AM
markb   Gen light takes it own special bulb. It is not th...   Apr 19 2008, 05:07 PM
Cap'n Krusty   Gen light takes it own special bulb. It is not th...   Apr 19 2008, 06:35 PM
effutuo101   That is a 5W bulb correct?   Apr 19 2008, 11:29 AM
sww914   I would buy a cheap multimeter and compare it to t...   Apr 19 2008, 02:20 PM
East coaster   Spoke, Thanks for the input. The car has been on t...   Apr 19 2008, 02:26 PM
Spoke   I don't think I can do the jumper too easily ...   Apr 19 2008, 06:24 PM
sww914   The alt energizer circuit runs through the alt lig...   Apr 19 2008, 03:21 PM
sww914   Here's a good article on 914 charging systems,...   Apr 19 2008, 03:29 PM
vsg914   Well, not sure of the specifics of the bulb itself...   Apr 19 2008, 05:55 PM
vsg914   Then why are they different? Enlighten me oh crust...   Apr 19 2008, 06:41 PM
East coaster   This is a 914-6 conversion with a 1992 3.6 Carer...   Apr 19 2008, 09:38 PM
- Lo-Fi Version Time is now: 12th July 2025 - 11:53 AM
