Issues painting sheet metal |
dbgriffith75 |
Apr 22 2008, 09:21 AM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
So as I'm rebuilding the engine on my 914, I've been repainting the sheet metal with, and I know it's not the best way but my budget is limited, spray paint. Not just any spray, it's Dupli-color Engine Enamel- a ceramic rated to 500 degrees. Problem is, the primer gray is showing through no matter how many coats I put on it. One piece must have about 20 coats on it and still the gray is showing through. I finally got to the point where I said screw it and sprayed on a really thick coat on one piece, telling myself that when it cured I'd just sand out the runs and put on a lighter top coat to finish, but even that isn't working. Any ideas if it's just the paint, or maybe I should just switch to a black primer? Thanks.
Cevan |
Apr 22 2008, 01:03 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Because I couldn't find a powder-coater willing to do my tin, I ended up using the Dupli-Color engine primer and paint (low-gloss). I also used it (gray) on the fan housing and intake tubes. I waited 10 minutes between coats and 7 days between primer and color. The low-gloss black covered the primer completely by the second coat and I think I did 3 coats of color total.
Lo-Fi Version | Time is now: 8th June 2024 - 05:17 PM |
