| MrKona |
Apr 23 2008, 11:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There was a recent thread about thermostats... it reminded me that the thermostat that came with the engine I'm building was broken, and I had to either buy a new, used one, or see if I could fix the one I have. I followed the informative article by Richard Atwell with good results. Ratwell link
My thermostat had sprung a leak somewhere which eliminated the negative pressure vacuum a functioning thermostat holds at room temperature. The thermostat is supposed to measure around 35mm in length at room temp, mine measured around 46mm, which is the normal expanded state length. I examined it closely and could not find any cracks around the perimeter, so I assumed there must be a break at a brazed surface. I was in luck, it was fixable! Just for kicks, I placed it in a hot water bath approximately 180 degree F, and there was no significant change in length, pre- to post-bath. Attached image(s)
| MrKona |
Apr 23 2008, 11:33 PM
Looks like it started opening a little early... At temp of 165F, it was now up to spec at 46mm. (IMG:style_emoticons/default/dry.gif)
MrKona Fixing my thermostat Apr 23 2008, 11:07 PM
MrKona First step was to remove the top on the side with ... Apr 23 2008, 11:13 PM
MrKona While I had the top off, I blew out any debris wit... Apr 23 2008, 11:17 PM
MrKona Next step was to inject approximately 2ml of 99% I... Apr 23 2008, 11:23 PM
ericread :popcorn: Apr 23 2008, 11:23 PM
MrKona With the alcohol now injected through the small ho... Apr 23 2008, 11:28 PM
MrKona And now for the water test.
At 140F, the thermost... Apr 23 2008, 11:32 PM
MrKona ... and at 184F, it had opened up to around 55mm, ... Apr 23 2008, 11:36 PM
ericread So what you are saying is that between "Rare ... Apr 23 2008, 11:51 PM
MrKona
So what you are saying is that between "Rare... Apr 24 2008, 01:15 AM
purple Classic thread? Apr 24 2008, 10:23 AM
jim_hoyland
Classic thread?
Definately ! Very nice writ... Apr 24 2008, 10:52 AM
dbgriffith75 That's a really good suggestion- I didn't ... Apr 24 2008, 10:51 AM
Steve Thacker Bryan,
Excellent post! You one smart coolie. ... Apr 25 2008, 11:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th October 2026 - 03:09 PM |
