| URY914 |
Apr 24 2008, 02:12 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,071 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
In case you missed this, I thought I'd share it with you...
In an attempt to be able to perform quicker gear shifts, I have raised my gearshift base and shift rod about 3" above the stock location. This means that the forward shift rod is above the center tunnel but still uses the stock firewall bushing. I figure if I move the gearshift closer to the steering wheel my hand will spend less time going between the wheel and the gearshift. I did not add universal joints to the shift rod. The coupling under the gearshift and at the firewall allows for some degree of mis-alinement. I fabricated the brackets so I could adjust them so if the mis-alinement was too great and the rod was binding up I could back it down and free it up. If I really wanted to raise it up 6" or so I'd have to add u-joints into the rod. Than I could also cut a few inches off the gear shift handle to reduce the throw. Maybe I'll do this next if this doesnt work out completely. This is not a pretty polished custom CNC fabricated aluminum piece but it works. I have not driven the car with it, but it is little more stiff that stock. I only use 1-2-3 anyway so I'll learn to live with it. Attached thumbnail(s) |
| McMark |
Apr 24 2008, 10:54 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
You should remove the 4/5 gears for weight savings... (IMG:style_emoticons/default/idea.gif)
That's a cool mod, have you thought about cable shifter? |
URY914 I moved my entire gearshift up Apr 24 2008, 02:12 PM
URY914 Photo #2... Apr 24 2008, 02:13 PM
lagunero yea but how much weight did you add? :D
Thanks f... Apr 24 2008, 03:30 PM
URY914 I've thought a lot about cable shifters but fr... Apr 25 2008, 07:20 AM
race914 Just received a catalog from SpeedwayMotors and in... Apr 25 2008, 09:04 AM
URY914 Good find race914. That's the ticket for repla... Apr 25 2008, 10:29 AM
Phoenix 914-6GT Patrick Motorsports sells that as well. They even ... Apr 25 2008, 10:36 AM
smdubovsky If you do the math, the metal firewall bushing is ... Apr 30 2008, 09:53 PM
Phoenix 914-6GT After just doing ALL the shift bushings and now ha... May 2 2008, 12:44 AM
rhodyguy the new fw shift bushings are crap anymore it seem... May 8 2008, 02:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:15 PM |
