'Nuther Q - Just pulled the front fan hub from the crank |
Gint |
Apr 29 2008, 06:28 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
What's to prevent oil from leaking from the back side of the hub through the bolt hole?
Cap'n Krusty |
Apr 29 2008, 07:54 PM
It's a precision taper fit, and damn tight, once the bolt is torqued to a mere 18 ft/lbs. The o-ring behind the hub seals the joint between the crank and the hub, the radial seal between the hub and the case. if your hub was loose, I'd REALLY carefully inspect the surfaces of both the crankshaft and the hub. use a bright light and magnification if necessary. Also look at the key and the keway in the crankshaft. Perfection is a must here, anything less can cause the hub and crank to separate during operation, and that's something you REALLY don't want to happen.
The Cap'n |
turtleturtle |
May 2 2008, 07:01 AM
Member Group: Members Posts: 127 Joined: 4-September 07 From: Corpus Christi Member No.: 8,074 |
if your hub was loose, I'd REALLY carefully inspect the surfaces of both the crankshaft and the hub. use a bright light and magnification if necessary. Also look at the key and the keway in the crankshaft. Perfection is a must here, anything less can cause the hub and crank to separate during operation, and that's something you REALLY don't want to happen. The Cap'n Yeah, make sure the hub is not damaged at all, because if it is, your wood drift key will never last. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:16 AM |
