Rogue |
Newbie ![]() Group: Members Posts: 40 Joined: 18-December 03 From: Propwash (16XS) D/FW, TX Member No.: 1,447 Region Association: Southwest Region ![]() |
Any one try it? (IMG:style_emoticons/default/blowtorch.gif)
After seeing Gints Rust-o-ration, it makes me want to blast mine just in case. I did the Longs and theyre OK, but hidden rust scares the hell out of me. Soda will not damage like sand or chem-strip, and leaves no residue or etch. No warped fenders and no acid between panels. It will not remove bondo or scale, but will make it show its ugly face. PS (Its not expensive or harmful to the enviroment.) |
kdfoust |
Senior Member ![]() ![]() ![]() Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California ![]() |
QUOTE(markd@mac.com @ Dec 29 2003, 09:00 PM) CO2 takes specialized equipment doesn't it? Yes. You need a blaster that is designed specifically for C02. Basically it's got a hopper into which you chuck a piece of dry ice. The dry ice is chopped up into the appropriate size for blasting. Actually after writing that I realize who simple the process really is. By now, C02 blasting has been around for quite a while, there may be some low tech version of the ice handler that a at home geek could use. I've only monkeyed with the industrial type stuff. Have fun, Kevin |
Lo-Fi Version | Time is now: 8th July 2025 - 05:42 PM |
