| MikeHall |
May 7 2008, 06:38 PM
Member ![]() ![]() Group: Members Posts: 55 Joined: 28-April 08 From: Camilla, GA Member No.: 8,983 Region Association: None |
I just got my 914 in today to find much more rust than the car was said to have. Most if very minor and I can repair without a problem. The one spot that has me worried is the section located in the spot in this picture. There is a nice 3" hole there and while looking up in the whole I see some custy rust on the wall between the engine and seats but its not that bad. Other than that it just looks like the rust is in the floor. The battery tray was rusted up bad but to be honest the area under the battery does not look bad at all. I guess this is the Hell hole that everyone is talking about but mine is not near as bad as the others I have seen. Maybe Im missing something but It looks like I can clean up all the rust inside the whole, treat it and then weld a patch on the floor. What do you think?
Mike Attached image(s)
| MikeHall |
May 7 2008, 08:40 PM
Never mind as I found more rust. I thought it was just bad surface rust but after doing some major scraping The Hell hole appeared. LOL It looks about like most all the ones I have seen so I guess I need more than just that little floor patch. I also got under the car and found another soft spot on the rear floor so I will be ordering the full rear floor pan just in case. Who has the best hell hole repair kit?
Mike |
| Todd Enlund |
May 7 2008, 08:49 PM
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,252 Joined: 24-August 07 From: Reed (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Never mind as I found more rust. I thought it was just bad surface rust but after doing some major scraping The Hell hole appeared. LOL It looks about like most all the ones I have seen so I guess I need more than just that little floor patch. I also got under the car and found another soft spot on the rear floor so I will be ordering the full rear floor pan just in case. Who has the best hell hole repair kit? Mike Engman makes the CSOB kit: http://engmanparts.com/hellholekit.php Restoration Design makes some of the parts, but oddly enough, nobody makes a stamped part to repair the hell hole itself, at least as far as I know... Do like Zach says... get all the tar off the floor to see how bad it really is. Check the lower inner firewall. Check the longs where the floor pan meets them. Pull the rocker panels off and look at the longs and jack points. Pull the vinyl off the sails. Check the cowl at the base of the A pillars. Check the trunk floors. (IMG:style_emoticons/default/welcome.png) |
MikeHall Rust repair. May 7 2008, 06:38 PM
McMark :thumbsup: May 7 2008, 06:41 PM
Vacca Rabite Grind out any SUSPECTED rusty area with a wire whe... May 7 2008, 06:44 PM
MikeHall Well this is by far the worst rust. The foors are ... May 7 2008, 06:50 PM
MikeHall I was going to ask if there is just a small sectio... May 7 2008, 06:50 PM
Todd Enlund
I was going to ask if there is just a small secti... May 7 2008, 07:20 PM
MikeHall Sure seems like that would be a popular patch pann... May 7 2008, 07:26 PM
jd74914 Mike,
When I go home on Saturday I'll look t... May 7 2008, 07:27 PM
Vacca Rabite Have you pulled all the black tar out of the floor... May 7 2008, 07:27 PM
MikeHall I Have done all of that beside the lower inner fir... May 7 2008, 08:53 PM
Vacca Rabite :ttiwwp:
Fer realz!
We have all gone through... May 7 2008, 09:07 PM
MikeHall Why oh why did I have to remove the tar from the f... May 8 2008, 10:36 AM
tdgray Wire wheel... scraper and lots of time. Kerosene m... May 8 2008, 10:38 AM
Vacca Rabite I used an angle grinder and a knotted wire wheel. ... May 8 2008, 10:43 AM
dflesburg Every 914 should come with a mig welder and a 4x8 ... May 8 2008, 10:53 AM
MikeHall
Every 914 should come with a mig welder and a 4x8... May 8 2008, 11:16 AM
MikeHall Is the engine shelf needed on these cars? The pass... May 15 2008, 12:57 PM
Todd Enlund
Is the engine shelf needed on these cars? The pas... May 15 2008, 02:12 PM
MikeHall Here are a few pictures of the rust.
Mike May 15 2008, 05:11 PM
MikeHall Rust. May 15 2008, 05:12 PM
MikeHall More rust. May 15 2008, 05:13 PM
sean_v8_914 rusty hell hole, common May 16 2008, 12:34 AM
Jeff Hail 914's rust from the inside out! Like Dorit... May 16 2008, 12:44 AM
MikeHall I have a good tail pan found so that should be eas... May 16 2008, 07:30 AM
Vacca Rabite
Whats the best Por or Rust bullet? Rust bullet wo... May 16 2008, 07:58 AM
Todd Enlund
I have a good tail pan found so that should be ea... May 16 2008, 11:21 AM
MikeHall You very well may be right. The only real problem ... May 16 2008, 10:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:17 AM |
