> Replacing my Brakes
purple
post May 12 2008, 11:10 AM
Pigeon feeders attract me
This weekend was step one of two of replacing the brakes on my '76. The previous owner upon selling to me told me that he had rebuilt the front calipers and the brake fluid looked very nice and fresh in the master cylinder. Looks like a nice fresh tank of ATE super blue..... I will find out later that what's in that tank doesnt look like what's in the brake lines....
I started this project because when turning the wheels in the rear to set timing, I can hear the left rear brake dragging, and loudly. I feared it was a bearing, but it wasnt. The brake was dragging. I lift the car and put it on 4 jackstands, the evil kind (IMG:style_emoticons/default/sad.gif) I need some proper pin-thru stands. I have all 4 tires under the car in case the car decides it wants to smoosh me.
I'm using 4 new rebuilt calipers from Eric Shea. With these calipers are 4 new rotors, new front bearings, new seals, 4 new softlines, all new pads. A total of $1038 in parts from Eric.
From the pic...the parts are gorgeous!
purple
post May 12 2008, 11:24 AM
On to the fronts!
I shot the rotor screws with PB blaster as well as the inner adjuster covers on the rear.... more on that later..
I moved to the front left caliper.
It was also pretty easy to get loose. you guys have to remember there is a locking tab that you have to bend back off of both front bolts before any loosing can be done. I turned my wheel full-left to more easily work on the caliper bolts, as they can be a pain to see.
I loosed the bolts and then undid the hardline... This caliper came off without coaxing and something that was wierd....I didnt have any fluid leak out of the hard line at all. I put some saran wrap over the MC and screwed the cover down over it as per the haynes manual. The only line to leak after this is still the left rear. I leaked around 30 cc's of fluid, starting red and gukky, ending up blue...
Here's the left front caliper. it was dragging slightly, but the bearing needs attention here on this one...
What's with the seals on the piston? is that right?
purple   Replacing my Brakes   May 12 2008, 11:10 AM
purple   After some more investigation, it turns out that n...   May 12 2008, 11:18 AM
purple   The right rear caliper came off pretty easily and ...   May 12 2008, 11:20 AM
purple   On to the fronts! I shot the rotor screws wit...   May 12 2008, 11:24 AM
purple   The last caliper to remove for the day is the righ...   May 12 2008, 11:25 AM
Joe Mama   Looks like a herniated disc from Joe Sharps XRays....   May 12 2008, 11:29 AM
purple   :WTF: How does this happen? These seals look com...   May 12 2008, 11:35 AM
Joe Mama   ATE makes a blue and gold colored fluid. I altern...   May 12 2008, 11:38 AM
purple   Oh good! Do I need DOT4 or DOT5?   May 12 2008, 11:44 AM
Joe Mama   ATE is DOT 4, I would avoid DOT 5 like the plague....   May 12 2008, 11:48 AM
purple   ATE is DOT 4, I would avoid DOT 5 like the plague...   May 12 2008, 11:49 AM
Eric_Shea   Good write-up. Fluid inside the handbrake mecha...   May 12 2008, 11:54 AM
purple   I'm hoping for some amazing stopping power...   May 12 2008, 11:59 AM
Eric_Shea   Silly-cone. Because our systems were designed f...   May 12 2008, 12:01 PM
Eric_Shea   I'd bet this was the initial problem with th...   May 12 2008, 01:33 PM
purple   Would that explain why no fluid leaked out of the ...   May 12 2008, 01:40 PM
Eric_Shea   Pretty much. Your lines were basically swollen ...   May 12 2008, 02:55 PM
purple   No wonder the holes in the brake lines looked so t...   May 12 2008, 03:01 PM
purple   I found a website that detailed the bleeding proce...   May 13 2008, 11:40 AM
Carlitos Way   I love seeing highly motivated individuals work on...   May 13 2008, 12:05 PM
purple   :D that's the first time i've been describ...   May 13 2008, 12:08 PM
purple   Some progress and some questions: I put the front...   May 16 2008, 09:06 AM
Eric_Shea   That be why we don't include them... :( Too...   May 16 2008, 03:14 PM
purple   Been a while since I updated the thread... Eric S...   May 31 2008, 08:32 AM
SLITS   How do you get all the air out of the system? Oh ...   May 31 2008, 08:57 AM
Eric_Shea   :agree: First off... it takes a "ton" of...   May 31 2008, 11:42 AM
sww914   I've used plenty of pressure bleeders and vacu...   May 31 2008, 01:05 PM
purple   thanks guys! Looks like the fiance will be com...   May 31 2008, 03:36 PM
purple   I hate this car. I want it out of my life. It dri...   Jun 1 2008, 02:27 PM
Eric_Shea   :( Hang tight... you're doing all the right t...   Jun 1 2008, 08:19 PM
Spoke   :( Next, did you set your venting clearance to ....   Jun 1 2008, 08:46 PM
John   I'm really not sure what is happening with you...   Jun 1 2008, 10:59 PM
purple   I'm really not sure what is happening with yo...   Jun 2 2008, 08:23 AM
Cupomeat   Well as it appears that you are giving up on it, I...   Jun 2 2008, 10:16 AM
ericread   Hey Purp; We've talked before and although I ...   Jun 2 2008, 11:27 AM
Spoke   Purple Wrote: the venting clearance.... I must not...   Jun 2 2008, 11:36 AM
rjames   Just checking to make sure that by "st...   Jun 2 2008, 11:50 AM
Lavanaut   oh, wouldnt it just figure this piece of shit nee...   Jun 2 2008, 11:56 AM
purple   oh, wouldnt it just figure this piece of shit ne...   Jun 2 2008, 12:17 PM
purple   The rear pads just dont seem right to me... if you...   Jun 2 2008, 12:00 PM
So.Cal.914   Purple, do you have a camara? Take some pic's,...   Jun 2 2008, 12:21 PM
markb   I've had a love/hate relationship with my car ...   Jun 3 2008, 01:00 AM
purple   Okay, I've calmed down a bit and realize a mis...   Jun 3 2008, 10:41 AM
Spoke   You wrote: "if you dont set it very well, doe...   Jun 3 2008, 12:12 PM
purple   Okay! The reason I think to take the spacers ...   Jun 3 2008, 12:33 PM
davep   Don't forget that the correct venting clearanc...   Jun 3 2008, 12:37 PM
purple   I think something else is at play... I just adjus...   Jun 3 2008, 07:56 PM
flesburg   Purple. I have been fooling with 914s since 1974. ...   Jun 3 2008, 10:16 PM
Spoke   Sounds like you got the venting clearance under co...   Jun 4 2008, 07:11 AM
John   If you really want a firm brake pedal, you can rep...   Jun 4 2008, 08:54 AM
purple   You know, you guys are right. I've never drive...   Jun 4 2008, 09:01 AM
rjames   I always thought the following proceedure was su...   Jun 4 2008, 11:50 AM
rhodyguy   if you don't have them you really need to orde...   Jun 4 2008, 12:01 PM
Eric_Shea   Ahhhhhhhhh... it's in your blood!! ...   Jun 4 2008, 11:32 PM
cwpeden   Just a note for those of us who are using a 19mm M...   Jun 4 2008, 11:46 PM
John   Just a note for those of us who are using a 19mm ...   Jun 4 2008, 11:52 PM
Eric_Shea   And less mechanical advantage. ;) Frankly, I t...   Jun 5 2008, 12:30 AM
davep   Frankly, I think way too much fuss has been made ...   Jun 5 2008, 07:54 AM
Smitty911   One thing to remember on working on any Car, is th...   Jun 7 2008, 11:12 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:34 PM
