Small red idiot brake light on tank gauge is blinking.... |
wbergtho |
May 14 2008, 08:50 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
My 76 I just bought has a lazy brake pedal (doesn't return) and the brakes feel real crappy & spongy. The little red brake idiot light blinks on & off constantly. Is this light hooked to the master cylinder sensor trying to indicate to me that if i drive the car another foot I'll probably loose all my brakes and die in a fiery & horrific crash? (IMG:style_emoticons/default/blink.gif)
r_towle |
May 15 2008, 10:45 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The parking brake electrical connection is a ground wire on the bottom of the e-brake handle...right near where all your loose change goes, and piles of crud and rust.
Lift up the carpet and get a vacuum under the ebrake handle first...then remove the spade connector and clean is. Then adjust your ebrake cables to the proper tension...that holds the handle down... Rich |
Lo-Fi Version | Time is now: 11th June 2024 - 03:40 AM |
