| narino |
May 15 2008, 07:02 PM
Member ![]() ![]() Group: Members Posts: 234 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None
So last February (2007) I saw The Bumper Shop had a deal to chrome each bumper for $175. Well unfortunately that deal was through Danny who I guess has gone his own way and left this shop.
The guys at the bumper shop are still interested in our group and have offered another deal of $275 per bumper. I guess their regular prices are $350 per bumper now. What do you guys think? This a good deal, or do others have a better option out there I have missed? We need minimum 5 bumpers to do it. Anyone interested in getting theirs rechromed with me? Gintedit - June 24, 2009: OK folks, this particular "group buy" completed last year. Chris (?) aka banger has stepped up to organize a new buy this year. He's started a new thread for same located here: http://www.914world.com/bbs2/index.php?showtopic=96986 Given that, we're going to close this thread and reference the new one. If you're interested in the deal, check out and post in the new thread. This post has been edited by Gint: Jun 24 2009, 08:25 PM |
| TravisNeff |
May 16 2008, 12:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
For your reading pleasure. Now if they are to skip the copper plating, are they going to do a nickel dip twice?
Decorative Chrome Plating Decorative chrome plating is sometimes called nickel-chrome plating because it always involves electroplating nickel onto the object before plating the chrome (it sometimes also involves electroplating copper onto the object before the nickel, too). The nickel plating provides the smoothness, much of the corrosion resistance, and most of the reflectivity. The chrome plating is exceptionally thin, measured in millionths of an inch rather than in thousandths. When you look at a decorative chromium plated surface, such as a chrome plated wheel or truck bumper, most of what you are seeing is actually the effects of the nickel plating. The chrome adds a bluish cast (compared to the somewhat yellowish cast of nickel), protects the nickel against tarnish, minimizes scratching, and symbiotically contributes to corrosion resistance. But the point is, without the brilliant leveled nickel undercoating, you would not have a reflective, decorative surface. By the way, there is no such thing as "decrotif chrome plating". That is just a misspelling of 'decorative'. Buzzwords: "Show chrome", "Triple Chrome Plating", "Double Nickel-Chrome" "Show chrome" probably means chrome that is good enough to be on a winning entry in a car show. Although most OEMs rely on the "self-levelling" property of nickel plating to give sufficient reflectivity to roughly polished steel, chrome-lovers believe that the key to "show chrome" is to copper plate the item first and then buff the copper to a full lustre before starting the nickel plating. Whether you start with bare steel or buffed copper, at least two layers of plating follow -- a layer of nickel and a layer of chrome. But high quality plating requires a minimum of two layers of nickel. Salespeople are always looking for advantage, and they will use any good-sounding terms they can get away with! There are no laws that define what triple chrome plating actually means, so salespeople will be prone to call their service "triple chrome plating" if there are a total of 3 layers of any kind of plating, or "quadruple chrome plating" if there are 4. So those terms mean little. The most important issue for durable chrome plating for outdoor exposure such as on a vehicle is that it MUST have at least two layers of nickel plating before the chrome: namely semi-bright nickel followed by bright nickel. The reason for this involves galvanic corrosion issues. The bright nickel is anodic to the semi-bright nickel, and sacrificially protects it, spreading the corrosion forces laterally instead of allowing them to penetrate through to the steel. OEMs demand very close control of this factor, and there is a test (the Chrysler developed STEP test) which large shops run daily to insure the right potentials. Careful control of this issue is probably the principal reason that today's chromium plating greatly outlasts the chrome plating of earlier times. Experts argue whether copper plating provides any additional corrosion resistance at all, but with or without copper plating, chrome on top of a single layer of nickel will not hold up to the severe exposure of a vehicle! Industry professionals call the two layers of nickel "duplex nickel plating", and that would be a much better term to use than "triple chrome" and such. Chrome plating is hardly a matter of dipping an article into a tank, it is a long involved process that often starts with tedious polishing and buffing, then cleaning and acid dipping, zincating (if the part is aluminum), and copper plating. For top reflectivity "Show Chrome", this will be followed by buffing of the copper for perfect smoothness, cleaning and acid dipping again, and plating more copper, then two or three different types of nickel plating, all before the chrome plating is done. Rinsing is required between every step. Restoration Work When an item needs "rechroming", understand what is really involved: stripping the chrome, stripping the nickel (and the copper if applicable), then polishing out all of the scratches and blemishes (they can't be plated over and any scratches will show after plating), then plating with copper and "mush buffing" to squash copper into any tiny pits, then starting the whole process described above. Unfortunately, simply replating an old piece may cost several times what a replacement would cost. It's the old story of labor cost. The new item requires far less prep work, and an operator or machine can handle dozens of identical parts at the same time whereas a mix of old parts cannot be processed simultaneously, but must be processed one item at a time. If a plater has to spend a whole day on your parts, don't expect it to cost less than what a plumber or mechanic would charge you for a day of their time. Peeling chrome? If your chrome plating is peeling, this is virtually always a manufacturing defect due to insufficient adhesion of the plating to the substrate. Although exposure conditions can certainly harm chrome, they don't make it peel. It can be very difficult for the plating shop to get good adhesion on some things (specifically on aluminum wheels) because they are not pure aluminum, but if they can't do it they shouldn't sell it. If your parts have peeling, you should complain and you should not be deterred by nonsense about chemicals in your garage, how frequently you wash the wheels, etc. We'll say it again, peeling chrome is virtually always a manufacturing defect. |
narino Chrome bumper deal (triple plate) May 15 2008, 07:02 PM
Headrage I had my bumpers done there last year.
Cost was ... May 15 2008, 07:08 PM
Wilhelm Interested, but have some bumpers with minor dings... May 15 2008, 07:09 PM
narino I'll call later this eve to check if the price... May 15 2008, 07:16 PM
Dr Evil Let me see if my friend has some spares he would l... May 15 2008, 07:48 PM
Headrage
Allan, Did your bumpers need any straightening wh... May 15 2008, 07:51 PM
jcd914 Can they chrome painted bumpers? May 15 2008, 07:52 PM
Headrage
They can but c... May 15 2008, 07:57 PM
porsche914gt $175 - $200 is a good deal. $275 is... May 15 2008, 08:29 PM
Lavanaut Any idea what they'd charge to fill (weld) bum... May 15 2008, 09:03 PM
Heeltoe914 I had four bumpers done last year and all where gr... May 15 2008, 09:35 PM
!Wet Spot! That sounds high....when I did my 58, I used Super... May 15 2008, 09:44 PM
dw914er yea, how much to get both done, and cover the ... May 15 2008, 11:56 PM
PanelBilly I don't have the name of the business, but a y... May 16 2008, 12:43 AM
TedK Those bumpers look nice...would you say they are s... May 16 2008, 10:07 AM
Heeltoe914
Those bumpers look nice...would you say they are ... May 16 2008, 12:30 PM
KaptKaos Has anyone ever done their bumpers in black chrome... May 16 2008, 10:13 AM
LvSteveH It's going to be hard to find someone willing ... May 16 2008, 10:14 AM
Lavanaut
Figure a nice core bumper is worth $150, plu... May 16 2008, 10:58 AM
Headrage I spent a couple of hours there when I had mine do... May 16 2008, 11:02 AM
Heeltoe914
I spent a couple of hours there when I had mine d... May 16 2008, 12:35 PM
sean_v8_914 many chrome shops have shut down in teh last 2 yea... May 16 2008, 11:23 AM
narino Ok, just got off of the horn with the shop. Here i... May 16 2008, 12:00 PM
Heeltoe914
Ok, just got off of the horn with the shop. Here ... May 16 2008, 12:48 PM
KaptKaos
[edit] crap forgot to ask about black chrome.
... May 17 2008, 04:11 PM
TedK It all depends on what you want as a final product... May 16 2008, 12:10 PM
Travis Neff isn't the copper plating process a very import... May 16 2008, 12:21 PM
LvSteveH There is no industry standard for "triple pla... May 16 2008, 12:29 PM
Wilhelm I believe you can put me down for 4 bumpers. May 16 2008, 12:46 PM
biosurfer1 You might try to find out how many people for sure... May 16 2008, 12:55 PM
narino
... if you have 20 confirmed, he might be willing... May 16 2008, 01:13 PM
r_towle I would not do it without the copper phase.
It is ... May 16 2008, 01:10 PM
Bartlett 914
It is... May 16 2008, 03:41 PM
Headrage One thing to remember guys is that when Danny set ... May 16 2008, 01:13 PM
Headrage
P.S. anyone have a garage and mechanical knowledg... May 16 2008, 01:15 PM
narino
If you can trailer the car I have access to our ... May 16 2008, 03:02 PM
914dave Jorge,
I'm interested in having both mine done... May 16 2008, 04:04 PM
Dr Evil I talked to my buddy and he is on board. I need to... May 16 2008, 04:29 PM
narino After I talk to them early next week I'll post... May 16 2008, 07:54 PM
freezing14 here in canada , its 600$ per unit so put me ... May 17 2008, 06:28 PM
warrenoliver :bump:
Where are you on this? Have a price yet?... May 20 2008, 09:46 AM
narino Alright. We got another deal.
With a commitment o... May 20 2008, 05:28 PM
396
With a commitment ... May 31 2008, 12:20 AM
JB 914
With a commitment ... May 31 2008, 01:03 PM
warrenoliver i've got 2 that i need! am i too late? :c... Jun 1 2008, 11:09 AM
TedK I'm in for 3 if it can wait till I get back in... May 20 2008, 05:59 PM
dw914er i will most likely be in, but more of midsummer du... May 20 2008, 08:39 PM
narino OK here is the information. Send your bumpers to t... May 21 2008, 10:24 AM
TedK 29th or 30th OK for me to deliver to Victor?? May 21 2008, 01:45 PM
rudedude Put me in also.
Do you need to pay up front or wil... May 21 2008, 01:46 PM
narino
Put me in also.
Do you need to pay up front or wi... May 21 2008, 04:11 PM
TedK Good deal, thanks for all the effort!
Ted K May 21 2008, 04:47 PM
porsche914gt I'm in for 3, and I'll drop off and pick u... May 21 2008, 11:18 PM
914dave Jorge,
This is a great deal! Thanks for the ha... May 22 2008, 05:10 AM
Headrage
Did they give you any idea of turn around time fo... May 22 2008, 07:40 AM
kconway Jorge,
Can I walk my 2 bumpers into this shop this... May 22 2008, 07:52 AM
Dr Evil I am gonna have my friend inventory his stock. He ... May 22 2008, 10:34 AM
narino Gladly guys! :beer2:
No need to be on the l... May 22 2008, 12:27 PM
narino Just talked to Victor. He assures me there will be... May 22 2008, 03:00 PM
sixgt Jorge,
Thanks for setting up the deal! Will ... May 22 2008, 05:58 PM
narino Hey guys could you post a reply here when you send... May 27 2008, 04:13 PM
warrenoliver
Hey guys could you post a reply here when you sen... May 28 2008, 04:13 PM
Dr Evil Warren, how much did it cost you? I am looking for... May 28 2008, 04:36 PM
warrenoliver
Warren, how much did it cost you? I am looking fo... May 29 2008, 03:51 PM
TedK OK, I took mine in to Victor today, very easy to w... May 29 2008, 05:26 PM
euro911 Did the subject of flatening out small dents ever ... May 31 2008, 01:01 AM
TedK I believe that is included in the base price. May 31 2008, 12:53 PM
narino Joe - yes, you can still get yours in, I'd tak... Jun 3 2008, 04:28 PM
euro911
Joe - yes, you can still get yours in, I'd ta... Jun 3 2008, 05:38 PM
Dr Evil My buddy has 3-4 that I have seen, but it is a pai... Jun 3 2008, 04:55 PM
narino Mike - Do you have the address to where to pick th... Jun 4 2008, 01:23 PM
Dr Evil
Mike - Do you have the address to where to pick t... Jun 4 2008, 03:23 PM
dw914er I should still be in. Just need to pay off a few t... Jun 4 2008, 01:46 PM
narino Right on. Here is the closest location to my offic... Jun 4 2008, 03:31 PM
Dr Evil It would not be a problem for them to hold it for ... Jun 4 2008, 03:48 PM
narino Hey guys, just talked to Victor. He's recieved... Jun 9 2008, 03:21 PM
euro911 Has anybody got their bumpers back yet? :unsure:
... Jun 10 2008, 12:41 AM
narino Yves Boucharv or a Darringer (from Ogdensburg NY) ... Jun 11 2008, 04:10 PM
kconway Went by The Bumper Shop today to pick up an emblem... Jun 16 2008, 02:28 PM
TedK Just picked mine up and they look great! Mine... Jun 18 2008, 03:30 PM
Headrage :ttiwwp: Jun 18 2008, 03:50 PM
Heeltoe914
:ttiwwp:
:agree: Show us your shinny ass?... Jun 18 2008, 05:55 PM
euro911 I hope they're still accepting bumpers :unsure... Jun 23 2008, 12:22 AM
euro911 Well, I didn't make it over there till today, ... Jun 25 2008, 09:55 PM
rudedude I received my rear bumper yesterday, it looks grea... Jul 10 2008, 03:48 PM
euro911 Nestor called me this morning and said mine are re... Jul 11 2008, 12:06 AM
Lavanaut ...nice Mark, I was just about to say I can't ... Jul 11 2008, 10:14 AM
KevinP I'm in! Let me know when. That is a great ... Jul 11 2008, 10:34 AM
euro911 "[i]When?" you ask? ... :unsure: ... [b]... Jul 11 2008, 11:04 AM
porsche914gt Couple of pics. Jul 11 2008, 11:11 AM
james2 Is it too late?
I would have to ship mine from GA... Jul 11 2008, 12:24 PM
euro911 No, it isn't too late ... I informed them that... Jul 11 2008, 04:41 PM
james2 I called and Victor is not in today.
I'll cal... Jul 11 2008, 05:37 PM
narino
Sorry I... Jul 11 2008, 06:04 PM
banger I need to have some bumpers re-chromed. Was wonde... Jun 22 2009, 12:55 AM
jk76.914
I need to have some bumpers re-chromed. Was wond... Jun 22 2009, 05:16 AM
ellisor3
I need to have some bumpers re-chromed. Was won... Jun 22 2009, 08:48 AM
banger I spoke to them today, and they said that if we ge... Jun 22 2009, 02:44 PM
Lavanaut They mention a turn-around time? I'm likely i... Jun 22 2009, 03:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th April 2026 - 05:34 AM |
