vesnyder |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 ![]() |
Is there any correlation between the oil level and the oil pressure? Will the oil pressure go down as the oil level goes down?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The pressure will vary depending on the level only if the level drops enough that the pickup tube starts sucking oil...
Alternately, if having less oil in the sump makes the oil heat up more, the heat will thin the oil out so the pressure will drop. Otherwise, no. The oil level has no direct relation to the oil pressure. --DD |
Lo-Fi Version | Time is now: 12th July 2025 - 11:42 AM |
