CRAP!!!!!! Emissions problems... HELP!, Need advice!! |
ninefourteener |
Dec 30 2003, 10:54 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
Ok.... Illinois decided that I had to get the teener inspected... so I did..... it passed everything EXCEPT the Hydrocarbons test. (I think.... thats the one that measures "unburnt fuel" right?) The max is like 800-something, and my car blew 3000-something.
Before ANYONE starts, my car runs INCREDIBLE, and I don't want to change, alter, adjust ANYTHING. Need to know if there's any special "tricks" I can use to get this thing through. Granted, the teener wasn't fully warmed up, cause it's so cold outside.... the gauge was only reading about 1/2 as high as normal operating temp.. would that cause it?? So.. here's the scoop.... the engine has about 6 or 7K miles on it. Its a 2.0, lots of minor upgrades to the heads, valves, cam, etc, but nothing too significant. I have the reciepts (just not with me now), and I know thew PO spent over $5k just on the engine it done right. It's NOT fuel injected.. it has been coverted over to dual Solex carbs.... and I know thats why its probably failing. I know I used to have an 80 Elcamino.... took out the 305, and dropped in a 396BB with a nasty cam. I ran the tank almost empty, dropped in 2 bottles of dry gas, and the thing passed emissions better than a honda Civic--LOLThe emissions guy knew I was full of shit, but who cares.. I passed. Will that work? Will running a teener on dry gas for 20 or 30 minutes severely hurt it?? Lastly... I don't want to be emissions exempt, nor do I want to register it as an antique.. I want to get this thing through inspections just like any other car. Any help is GREATLY appreciated (IMG:style_emoticons/default/smile.gif) |
Hi_Fi_Guy |
Dec 31 2003, 10:55 AM
Tuetonic terror Group: Members Posts: 375 Joined: 12-August 03 From: Sunny Phoenix, AZ Member No.: 1,019 |
QUOTE(MarkV @ Dec 30 2003, 10:35 PM) If the car runs good I wouldn't screw with re jetting the carbs. When I couldn't pass everything I read said that high HC comes from ignition. Factory 6's came with a CD ignition to help clean up the dirty idle circuit of the carbs. I was able to get mine under the AZ 400ppm limit without re jetting carbs. On my first test the car was putting our 2500ppm & I got it down to 367ppm. You changed the ignition and passed? Or did you need to do more tuning? |
Lo-Fi Version | Time is now: 9th June 2024 - 11:22 PM |
