CRAP!!!!!! Emissions problems... HELP!, Need advice!! |
ninefourteener |
Dec 30 2003, 10:54 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
Ok.... Illinois decided that I had to get the teener inspected... so I did..... it passed everything EXCEPT the Hydrocarbons test. (I think.... thats the one that measures "unburnt fuel" right?) The max is like 800-something, and my car blew 3000-something.
Before ANYONE starts, my car runs INCREDIBLE, and I don't want to change, alter, adjust ANYTHING. Need to know if there's any special "tricks" I can use to get this thing through. Granted, the teener wasn't fully warmed up, cause it's so cold outside.... the gauge was only reading about 1/2 as high as normal operating temp.. would that cause it?? So.. here's the scoop.... the engine has about 6 or 7K miles on it. Its a 2.0, lots of minor upgrades to the heads, valves, cam, etc, but nothing too significant. I have the reciepts (just not with me now), and I know thew PO spent over $5k just on the engine it done right. It's NOT fuel injected.. it has been coverted over to dual Solex carbs.... and I know thats why its probably failing. I know I used to have an 80 Elcamino.... took out the 305, and dropped in a 396BB with a nasty cam. I ran the tank almost empty, dropped in 2 bottles of dry gas, and the thing passed emissions better than a honda Civic--LOLThe emissions guy knew I was full of shit, but who cares.. I passed. Will that work? Will running a teener on dry gas for 20 or 30 minutes severely hurt it?? Lastly... I don't want to be emissions exempt, nor do I want to register it as an antique.. I want to get this thing through inspections just like any other car. Any help is GREATLY appreciated (IMG:style_emoticons/default/smile.gif) |
fuch toy |
Dec 31 2003, 11:01 AM
Unregistered |
If you lean out the engine to get the HCs down, make sure you return it back soon....Badd things can happen......
Common trick to fool the machine....but the car usually runs like crap. Limp to the test, pass, get out and adjust the timing..... |
Lo-Fi Version | Time is now: 10th June 2024 - 12:51 AM |
