> gas tank, help
Howard
post Aug 1 2003, 10:52 AM
Incontin(g)ent Member
Another newbie question. Just bought a 73 2.0 and took it to a local Porsche mechanic to check. All is well, but he says I need a new fuel tank, as it's full of rust. Enough to clog injectors, so mus tdo something. Porsche doesn't make them any more, but he knew of a place that 'rebuilds' them @ about $400.
Ouch! Ideas?
jridder
post Dec 31 2003, 05:02 PM
>$75 to take your tank to a radiator shop and get it boiled and coated.
Where? I called about 5 places in the San Jose area and the price ranged from $125 to $145. My tank is a little rusty but doesn't look too bad so I was just going to get it boiled and coated instead of replacing it.
How much do good used tanks go for? I assume these are probably fairly rust free but not coated. How much does the coating help anyways?
Also, I will be converting to AN fittings. I'll document they way I do it. My first plan was to modify a AN-6 adapter on my lathe so that it fits in like the original tube (after making the hole in the aluminum nut bigger). This would probably be a good way for someone that doesn't want to remove/refinish their tank.
Then I figured I would tap the tank with a 1/4-NPT tap. This should work pretty well and will give about a 0.300" opening that is close to the size of 3/8" hard line / AN-6 hose.
Now, since I have to refinish the tank anyway, I'll probably just fill it with water, then weld on a couple AN-6 or AN-8 fittings. Its been hard to find information on just what size fitting I should go with. It seems that the 3/8" hard line (and an AN-6 fitting) should work for up to about 400HP, but I assume it will handle more HP with a high pressure fuel injection pump mounted by the tank.
Jonathan
Howard   gas tank   Aug 1 2003, 10:52 AM
SirAndy     Aug 1 2003, 11:22 AM
garyh   $75 to take your tank to a radiator shop and ...   Aug 1 2003, 11:27 AM
Howard   Thanks, guys.   Aug 1 2003, 12:26 PM
need4speed   I think POR-15 makes a kit for reconditioning, cle...   Aug 1 2003, 01:00 PM
scotty   Did the POR-15 dance... PITA getting the sealer ou...   Aug 1 2003, 08:04 PM
Howard   Me again. Since I plan to race the beast, how abo...   Aug 1 2003, 10:32 PM
Rob Ways   If you're tank was well rusted, it probably sa...   Aug 1 2003, 11:08 PM
jridder   >$75 to take your tank to a radiator shop and...   Dec 31 2003, 05:02 PM
garyh   <...   Dec 31 2003, 07:51 PM
d914   I got a cheap fuel cell, $50.00 8 gal plastic...   Dec 31 2003, 08:20 PM
jridder   >8 gal plastic drag cell with foam Fab works no b...   Jan 2 2004, 04:29 AM
ArtechnikA   <...   Jan 2 2004, 07:52 AM
John2kx   My fuel tank developed a small leak and had rust a...   Jan 2 2004, 08:16 AM
RON S.   Howard, As long as your tank doesn't leak,It ...   Jan 2 2004, 08:29 AM
jridder   > and there's a limit to how fast you can suck...   Jan 2 2004, 02:26 PM
d914   the 8 gal should last for at least 3-4 laps!...   Jan 2 2004, 02:30 PM
F4i   I would like to see that AN conversion if someone ...   Jan 2 2004, 05:17 PM
ArtechnikA
  Jan 2 2004, 07:31 PM
rdauenhauer   I recently went through this same thing this summe...   Jan 2 2004, 07:32 PM
jridder   >When it came out, no rust inside and no paint out...   Jan 3 2004, 01:19 PM
- Lo-Fi Version Time is now: 9th July 2025 - 03:10 PM
