yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
So I need some advice on this one:
2 years ago a CV went on me during an autocross, drivers inside (tranny side). The bearing race cracked and well, u know what happens then, no power transmitted means flatbed tow truck home. Replaced all 4 CVs with the kit from PMB performance. All was well.... fast forward to today, the exact same joint blew. I haven't dissasembled for a post mortem but it isn't pretty. Luckily i flat tow the car to events now so getting home wasn't a problem. The car definitely took a beating today, put about 45 total runs (autox school x 2 drivers) on the car before it let go on Avon Tech RA tires, a few areas of the course induced some slip/grip stress. Motor is relatively stock, probably putting out about 100-110hp crank. AutoX definitely put exess wear and tear on the part, running semi-sticky tires. So what should I do, replace with another kit? OEM? Beef it up with 944 or heavy duty CVs? Any of you fellow autoxers have a solution that won't cost me a fortune? Thanks! |
yarin |
Here are pics. The bearing race cracked, exact same failure mode as last time (2 years ago).
Dave - running 24-26 psi hot. Can anyone think of why the same CV failed? Is there something specific to torque distribution or the way the diff works that would cause the left side to go first? Could it be generally related to the clockwise nature of the autox course? Strange.. Anyhow, i feel like if i replace it with another kit, it will fail again, just a question of when. I'm sure this wouldn't be a problem for a street car, R compound tires + autox put a fair amount of strain on the joints. The lots we run in tend to have slight humps leading to the rear end getting light and tires slipping under accel. Combine that with a few spins here and there... boom. (IMG:style_emoticons/default/blink.gif) Attached image(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 11th July 2025 - 06:10 AM |
