| VaccaRabite |
May 24 2008, 08:49 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Okay, a while back I had the #2 exhaust rocker back off while breaking in the engine.
I fixed that, and rebuilt the carbs. Tonight I reset the valve gap and, ran it for the first time. It runs, but I heard a noise I did not like. There is a leak somewhere on the 1/2 head bank. Watch this video I made. it is me cranking the engine on my test stand. No fuel or spark, only cranking. The spark plugs are in to force compression. You can hear a "fffffffft, fffffffft, ffffffffft" sound, that I don't think is supposed to be there. Link to the video on Flickr Zach |
| VaccaRabite |
May 25 2008, 09:00 AM
Yeah. I fired it. It runs on all 4. Each carb is drawing the same amount of air. I have the idle set at 2K in order to seat the rings, but it was idling fine at about 650 rpm before I opened up the idle adjustment screws.
There could be an exhaust gasket leak between the stub pipe and the header pipe. I have had to take the 1/2 head pipes off a few times, and the gaskets have seen better days. But I did not see fit to source new gaskets until I was done taking the pipes off. I have to remove those pipes in order to use the Tangerine lifting plate. I'll take a vid of the engine running this afternoon after I am done baby duty, and have the corn and beans planted. Zach |
Vacca Rabite What does this leak sound like (video) May 24 2008, 08:49 PM
Vacca Rabite Also, and I am frusterated by this, but I am going... May 24 2008, 09:01 PM
Vacca Rabite Bump to the top.
Zach May 25 2008, 05:47 AM
vsg914 Zach, its hard to tell in the vid as sound quality... May 25 2008, 07:16 AM
toon1 I can sorta hear what you are talking about, hard ... May 25 2008, 08:52 AM
toon1 An EX leak would have to be pretty large to be abl... May 25 2008, 09:26 AM
rhodyguy use a section of garden hose to pin point the nois... May 25 2008, 09:48 AM
LowGT Maybe a silly question, but are the spark plugs to... May 25 2008, 05:08 PM
Vacca Rabite Vid of the first few moments of break in...
Ther... May 25 2008, 05:25 PM
bottomend
The... May 25 2008, 10:38 PM
purple why are you doing this with the tranny in gear? I ... May 28 2008, 04:08 PM
Vacca Rabite
why are you doing this with the tranny in gear? I... May 28 2008, 08:26 PM
r_towle grab the ball and go forward and back with it...yo... May 28 2008, 09:04 PM
Gint BTW - With the engine running the trans will turn ... May 28 2008, 10:42 PM
Vacca Rabite
BTW - With the engine running the trans will turn... May 29 2008, 07:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:43 PM |
