Push rod tube seals, how long of a job? |
tod914 |
May 25 2008, 10:37 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Just trying to get a ball park idea on how long it will take a competent mechanic
to replace the push rod tube o-rings on a 4 banger. Read through the posts, seems some like viton, others including Jake, prefer the OEM green/red style. Guess OEM is a safe bet to have installed? Any comments appreciated. Thanks, Tod |
ClayPerrine |
May 25 2008, 10:55 PM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I did the pushrod tube seals in Betty's car today. That part of the job took maybe 90 minutes. But I also took three trips to various stores, including one run to 3 auto parts stores, thoroughly cleaned the outside of the motor, removed the heat exchangers, repaired the muffler support bracket, and replaced the left rear trailing arm because the inboard bushing had disintegrated.
And I only spent 8 hours out there. I was kinda moving slow too. |
Lo-Fi Version | Time is now: 12th June 2024 - 06:36 AM |
