> D-Jet head temp sensor question
Joe Bob
post May 27 2008, 05:02 PM
Anyone have the specs on the resistor that is used on the 74, 2.0 head temp sensor? I have a lean condition and need the sensor....how many ohms?
toon1
post May 27 2008, 09:54 PM
QUOTE((*)(*) @ May 27 2008, 05:31 PM) *
When warm at idle it goes lean. Brain knob is all in at full rich.
Krusty's "nose" tells him it's lean....
QUOTE((*)(*) @ May 27 2008, 06:27 PM) *
As rare as they go bad....I'm leaning toward the ECU being the culprit.
http://members.rennlist.com/pbanders/DJetParts.htm
Per Brad Anders site....the 73 was the one that had a ballast resistor.....
So...yes, Travis you were right. (IMG:style_emoticons/default/pray.gif)
If it's warm and lean I would guess it's NOT the CHTS. when the engine warms up, the ECU ignores the CHTS.
NOT doubting Krusty, but how do the plugs look?
What about bumping the F.P.?
(*)(*)   D-Jet head temp sensor question   May 27 2008, 05:02 PM
Travis Neff   You add resistance to lean out the mixture. Only ...   May 27 2008, 05:05 PM
(*)(*)   Not according to the Krusty one....it's lean, ...   May 27 2008, 05:07 PM
Travis Neff   Hmm. Here's a snippet from Brad's Djet pa...   May 27 2008, 05:10 PM
toon1   At what point are you lean? during W/U or at opera...   May 27 2008, 05:21 PM
(*)(*)   When warm at idle it goes lean. Brain knob is all...   May 27 2008, 06:31 PM
(*)(*)   As rare as they go bad....I'm leaning toward t...   May 27 2008, 07:27 PM
markb   Checking the pbanders site, the 74 2.0 had a diffe...   May 27 2008, 08:11 PM
Bleyseng   Checking the pbanders site, the 74 2.0 had a diff...   May 27 2008, 09:52 PM
r_towle   go buy a POT and put it inline. one that goes from...   May 27 2008, 09:38 PM
jasons   go buy a POT and put it inline. one that goes fro...   May 28 2008, 01:45 PM
toon1   When warm at idle it goes lean. Brain knob is al...   May 27 2008, 09:54 PM
Travis Neff   Dirty-clogged injectors? My 1.7 djet has the same...   May 27 2008, 11:40 PM
davep   http://www.914world.com/bbs2/index.php?showtopic=8...   May 28 2008, 08:23 AM
markb   From Paul Anders' site: Cylinder Head Temper...   May 28 2008, 01:35 PM
(*)(*)   yep...I found that same variable resistor....I see...   May 28 2008, 02:11 PM
(*)(*)   Spoke with another friend of mine...factory traine...   May 29 2008, 09:41 AM
r_towle   Spoke with another friend of mine...factory train...   May 29 2008, 11:23 AM
jasons   Do you have the right match of FI parts? If you h...   May 29 2008, 09:55 AM
(*)(*)   Haven't had the chance to try it. The '1...   May 29 2008, 10:02 AM
(*)(*)   As mentioned before, I took it to Krusty because H...   May 29 2008, 11:32 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:44 PM
