> Possible Lean condition in L-jet motor - HELP, Fuel injection issues
Cupomeat
post May 28 2008, 04:11 PM
missing my NY 914 in VA
Ok, I am having the following problem on my 1.8l Ljet induction 914 motor.
First the basics;
1.9L (96mm big bore kit with KB pistons etc.)
8.4 to 1 CR
1.8 heads built out to 2.0l valve sizing, etc.
Stock fuel injection with adjustable FP regulator turned 15% higher than stock, currently(Pre-Lambda L-Jet, bummer)
Now, the symptoms;
Under normal acceleration, the car runs great and sounds fine, but under prolonged full throttle, the engine heat seems to go way up and pinging occurs. No pinging ever happens when I am rowing through the lower gears, but only seems to happen in 5th gear after prolonged Wide Open throttle (WOT).
So, my assumptions;
1. The car is going lean at prolonged WOT resulting in high head temps and pinging.
2. Ignition timing does not seem to play a role in this as I've played around with retarding the timing to decrease the pinging, but it never goes away at Prolonged WOT.
My plan;
1. Buy a WB Fuel/air ratio gauge and weld in the bung for the 02 sensor to support my theory
2. I have an inline fuel pressure gauge in the engine compartment, but can't watch it when I drive the car, especially in 5th gear at WOT (for very long, LOL)
3. Check to make sure the throttle switch is working to trigger WOT
4. If #3 is fine, is it possibly the fuel pump is running out of pressure?
5. I am also going to install a remote oil cooler to try to bring the heat down, but on a mild 1.9l, it seems excessive, especially as I probably have about 85 hp.
6.Probably install a cyl head temp gauge to try to pinpoint temps besides oil.
7In the end, if I have to pay for Dyno time to get to the bottom of this, I will but I'd rather not spend that yet.
Anything else people can think of? Any help/thoughts would be appreciated.
Eric
Cupomeat
post May 29 2008, 01:35 PM
Thanks,
As for fuel octane, I always run 93 since I first experienced the issue so I believe I can rule that out given the reasonable CR ratio (IMHO).
Also, as per the Bosch book, the Air Flow meter only affects mixture up until about 3500 rpm and then it is all about mapping on the analog FI brain based on RPM and the throttle position sensor. As the TPS has only 3 possible circuits, clearly it is not a high accuracy fuel metering at high RPMs. I will try the enrichment of the AFC once I get my WBO2 sensor if the problem exists as low RPM also.
I'll go the WB02 route but I was looking to see if anyone experienced this before, and if so, any possible explanations.
In my mind, the following are possible
1. The fuel pump runs out of pressure at sustained WOT
2. The TPS is not triggering full enrichment or another component/wiring is failing to make a difference
3. The Fuel filter is clogged (doubtful)
4. the whole setup isn't delivering enough fuel all along.
Another thing I've found is that the car sometimes starts to miss at redline. I do not have a rev limiter in it and there appears to be no rev limiter built into the AFC analog computer. Possibly this is related?
Also, the car doesn't idle very well if you rev and let it drop down. It will idle fine if you don't blip the throttle. I have verified that there are no intake leaks so I am obviously looking at something else here. Possibly this is related?
Just trying to follow the scooby doo path of finding clues to who is the ghost in the machine. (doubt this one is Old Man withers from the Carnival)
Thanks again for helping me think this one through.
- Lo-Fi Version Time is now: 16th July 2025 - 12:40 PM
