Leak Down Testing - Help |
vesnyder |
May 29 2008, 10:22 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am trying to understand how to use my new leak down testing tool from HarborFreight. I am trying to see if my rings are sealing on my rebuilt motor. I hook everything up and I can hear the air through the oil filler but the gauge reads 0% leakage? I can hear it leaking so I know it is not zero - is the tool broken? (it is HF after all) What is the typical pressure when zeroing out the % leak down gauge? Mine reads 12 psi - seems low but the pressure may be irrelevant when determining leak down?
Thanks! |
brant |
May 29 2008, 11:00 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don't quite understand your question
do you mean your intake pressure is 12psi? most of the guages work at 100psi (I have seen 50psi ones, and then you double your results to figure leakdown) so the motor needs to be hot pull the plugs 1 at a time as your doing that cylinder turn it to tdc for that cylinder before pulling the plug. (the reason is that if you were to drop a bit of carbon as you pulled the plug, the valves would be closed for that cylinder already and eliminate the chance that the bit that dropped could get under the valve) incoming air at OVER 100psi crank the incoming air down below that (failure to do so can damage the guage) install guage. crank air up to 100 see what 2nd dial reads for leakdown numbers that should do it oil filler would be rings. exhaust would be exhaust valves carbs would be intake valves brant |
Lo-Fi Version | Time is now: 8th June 2024 - 09:18 AM |
