Leak Down Testing - Help |
vesnyder |
May 29 2008, 10:22 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am trying to understand how to use my new leak down testing tool from HarborFreight. I am trying to see if my rings are sealing on my rebuilt motor. I hook everything up and I can hear the air through the oil filler but the gauge reads 0% leakage? I can hear it leaking so I know it is not zero - is the tool broken? (it is HF after all) What is the typical pressure when zeroing out the % leak down gauge? Mine reads 12 psi - seems low but the pressure may be irrelevant when determining leak down?
Thanks! |
vesnyder |
May 30 2008, 06:08 AM
Brant - The directions said to apply the pressure and adjust 'til the second gauge says 0%. It was at this point the first gauge is reading 12psi? When I crank the incoming over that the second gaquge is off the scale. Will exchange today and see if it is the operator or the equipment.
Lo-Fi Version | Time is now: 8th June 2024 - 06:57 AM |
