Lavanaut |
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest ![]() |
Something's not right. Smells like exhuast in the cabin, and a very slight backfire has developed on the left side...like a very subtle 'pop pop pop' at idle, and a more pronounced, single 'POP' on decel around 2800-3100 RPM. I've got it paired up to a Triad exhaust. What gives?
I swore to my wife that I wouldn't have the car up on ramps for a while since I just pulled it down (after 2.5 months) 2 days ago, so I took it to a custom exhaust place here in town and had them do the install. They said I needed new hoses (parts 21 & 23 here, hope you don't mind George!). The original ones were put back on, but they're pretty deteriorated and have small holes/cuts in them. Could that be it? I wish I understood how heat exchangers worked. I did a search on google hoping to learn just that but came up empty. Yes, I realize that if there's exhaust pouring into the cabin it could potentially be fatal. I drove the car home with the windows down. (IMG:style_emoticons/default/smile.gif) I intend to contact the shop today, but was hoping to get some feedback from you all first. Thanks in advance Reid |
Lavanaut |
I must not have been clear. With the HE off of the car, they blocked off one end and put 15 lbs. of pressurized air to the other end and could hear it "leaking like crazy" underneath the heat shield. It has a leak, that much is certain at this point.
After further consideration though, I'm going to have them fix it. (IMG:style_emoticons/default/welder.gif) |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I must not have been clear. With the HE off of the car, they blocked off one end and put 15 lbs. of pressurized air to the other end and could hear it "leaking like crazy" underneath the heat shield. It has a leak, that much is certain at this point. After further consideration though, I'm going to have them fix it. (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 11:30 AM |
