Engine/trans mechanical restart procedure? After long hibernation, Searched...nothing found |
JeffBowlsby |
Jun 4 2008, 03:36 PM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
What procedure should be followed to restart a stock engine that has been sitting a while...like 10 years or more? Just the mechanicals, Not FI, Not electrical etc.
Here are my thoughts, what else should be done? Engine Drain engine oil, install new oil filter Flush crankcase with 2-3 quarts of Marvel mystery oil, drain *check for internal corrosion Fill crankcase full of Marvel oil, let soak for at least a month (How much Marvel oil will fill the case?) Drain Marvel oil, install new oil filter and fill with motor oil Replace pushrod tube seals, valve cover gaskets Hope that rear crank gasket does not leak, replace if req'd Check for leaks, repair leaks Check/adjust valves Transaxle Drain trans oil Flush trans with 1-2 quarts new oil, then fill Hope front trans seal does not leak, replace if req'd Check for leaks, repair leaks *I may have access to a borescope from work that may get me get into the gas tank, cylinder chambers and any other orifice to check for internal corrosion, cylinder scoring etc and will do that if I can borrow the scope for a weekend. |
JeffBowlsby |
Jun 4 2008, 05:14 PM
The thinking behind using the Marvel oil fill and flush, and especially in letting it soak, was to:
*Penetrate all the nooks and crannies inside the case, flush out old dried oil deposits, before new oil is installed, especially at oil galleries and between adjacent moving parts – bearings, bushings, piston rings/cylinders etc. *Loosen up corrosion and flush it out before it causes damage. *Prime oil galleries and the oil pump that are empty or dry *Saturate all engine internals in a low viscosity lube as a prelube between any moving metal parts to prevent or minimize damage during those initial rotations, before the oiling system will function. Cam lobes, bearing surfaces, piston rings/cylinders, valve guides *Find oil leaks early before they become big leaks *Saturate seals at rear crank oil pump and oil cooler that may be dried out After this cleaning/soaking process, before ignition, the engine should be cranked over 10-20 times with the final oil in it, to get the oiling system functioning. Still think this is not needed? |
Lo-Fi Version | Time is now: 10th June 2024 - 07:55 PM |
