Pics needed for Ford solenoid setup |
7275914911 |
Jun 3 2008, 11:26 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
i believe i have seen them on the site but can not find them now. would like to see the wiring inparticular.
thanks in advance for any help jkp |
7275914911 |
Jun 4 2008, 11:18 PM
Amazing...
'Band-Aid' or not, it seems to work... I had previously cleaned all ground connections, beefed up tranny to body strap and re-routed battery ground to tranny case(it was grounded on the body by PO who had moved battery to trunk). This seemed to work for a while, BUT. So starter/solenoid was next stop. Ford Solenoid- $10; 4 Ga Strap- $4; 914 that always starts-priceless I went with the spot on the tin instead of on the starter. Looks more stable on the tin. It uses both mounting holes in solenoid! I used screws to mount with the thought of going back later with a helper and replace screws with bolts because of vibration. (IMG:style_emoticons/default/driving.gif) jkp |
Lo-Fi Version | Time is now: 12th June 2024 - 01:14 AM |
