yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
So I need some advice on this one:
2 years ago a CV went on me during an autocross, drivers inside (tranny side). The bearing race cracked and well, u know what happens then, no power transmitted means flatbed tow truck home. Replaced all 4 CVs with the kit from PMB performance. All was well.... fast forward to today, the exact same joint blew. I haven't dissasembled for a post mortem but it isn't pretty. Luckily i flat tow the car to events now so getting home wasn't a problem. The car definitely took a beating today, put about 45 total runs (autox school x 2 drivers) on the car before it let go on Avon Tech RA tires, a few areas of the course induced some slip/grip stress. Motor is relatively stock, probably putting out about 100-110hp crank. AutoX definitely put exess wear and tear on the part, running semi-sticky tires. So what should I do, replace with another kit? OEM? Beef it up with 944 or heavy duty CVs? Any of you fellow autoxers have a solution that won't cost me a fortune? Thanks! |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
All of mine slip on without pressing. That does look a little large, but then again, the newer parts ain't what they usta be.
And don't look a gift CV in the mouth... Hows the tranny and engine mounts, and the training arm bushings??????? Ken |
Lo-Fi Version | Time is now: 11th July 2025 - 08:51 AM |
