> Fuel pump issues, no power to pump
Tab914
post Jun 9 2008, 11:21 PM
Hello all,
Well took the teener out today to start my summer driving. Charged the battery and car started on first cranks. Let the car run for a bit, turned it off and turned it back on. Pulled out of the garage and took pictures to get a new insurance policy and let the car sit for half an hour.
Here is where the fun begins. Go to start the car to put it back in the garage and......nothing. Don't hear the fuel pump buzz when I turn the key. Push the car back in the garage and start testing.
The car is a 1974, 2.0lt d-jet.
Direct power to the pump shows that pump works.
Jumping the relay shows that power from the relay board will reach pump.
When pump is running while jumping the relay, the car cranks but won't start.
Then, when checking the main power relay, looks like I am getting no power to the relay board.
Swaped out the computer (brain) for another and still no power to the relay board.
Tried jumping the wires at the relay under the passenger seat and still nothing.
Been going over and over the electrical diagrams and getting nowhere.
Got tired and can't think anymore.
Very frustrating after having the car start right off the first crank.
Is there something simple I am not thinking of?
Thanks in advance to whoever can help. Appreciate all answers / suggestions.
Will check tomorrow after a nights sleep.
Cheers,
Dominic. (IMG:style_emoticons/default/beer3.gif)
dbgriffith75
post Jun 10 2008, 11:22 AM
TheGrif
At the moment I'm pretty sure it's a power to the relay board issue.
Okay, I'm not 100% sure on where all power feeds into the relay board from, but I have to ask: is the fuel pump the *only* thing not working when the key is turned on? Do other devices that run off the board get power, such as the motor blower, coil, and alternator? (Okay I know the alternator doesn't "run" off the board, but there's a harness that runs between it and the board.)
I'd check to see if you're getting power to these as well, because if you are, it might be that you've got a bad circuit in the board itself. Or there's just a bad ground that you're not finding. You might also want to check your voltage regulator- if its bad, it might be cutting off power to the pump. Just a thought, but I don't know for sure that the circuit runs through the regulator.
Just a few things to check out.
Tab914   Fuel pump issues   Jun 9 2008, 11:21 PM
SirAndy   try swapping the relay for one of the headlight re...   Jun 9 2008, 11:50 PM
ejm   This power comes to the board thru one of the re...   Jun 10 2008, 05:27 AM
Tab914   Hey Andy, Thansk for the reply. I tried that firs...   Jun 10 2008, 08:54 AM
ericread   A couple of ideas: 1. Are you sure the fuel pump i...   Jun 10 2008, 09:03 AM
Dave_Darling   A couple of resources for you-- Text troubleshoot...   Jun 10 2008, 09:32 AM
Tab914   Hey Eric, Did that as well and that did show me t...   Jun 10 2008, 09:34 AM
Tab914   Dave, Wow. A lot of info in there. Haven't...   Jun 10 2008, 09:57 AM
dbgriffith75   Okay, I'm not 100% sure on where all power f...   Jun 10 2008, 11:22 AM
wertygrog   hmm...my fuel pump stopped working a few days ago....   Jun 10 2008, 10:13 PM
ericread   WOW! Dave Darling's stuff is amazing...   Jun 11 2008, 08:35 AM
Dave_Darling   You mean Bill Williams' article, and the amazi...   Jun 11 2008, 09:37 AM
Tab914   Well the flow charts are great. From isolating the...   Jun 11 2008, 11:26 AM
ericread   Glad to hear you're mobile again! :drivin...   Jun 11 2008, 02:55 PM
swl   Dominic, Pin III is not exactly a ground point. T...   Jun 12 2008, 08:26 PM
Tab914   Thanks Steve. Good to see a fellow canuck replyin...   Jun 12 2008, 09:41 PM
roadster fan   Well, I had this same problem on my 71 a while bac...   Jun 12 2008, 10:02 PM
roadster fan   The following pics are of the 015 ecu and relay bo...   Jun 12 2008, 11:28 PM
roadster fan   Oh, forgot the transistor pic and the pic of ...   Jun 12 2008, 11:33 PM
swl   Intermittent can be a beast. If you can catch it ...   Jun 13 2008, 05:49 AM
Tab914   Jim, Wow, nice post. Thanks for the pics and the ...   Jun 13 2008, 09:34 AM
swl   Hey Dominic, I just went over your other post abou...   Jun 13 2008, 04:31 PM
Tab914   Hey Steve, Going out to the garage now to try and...   Jun 15 2008, 09:17 AM
Tab914   Well after being at it all day I finally got the c...   Jun 15 2008, 10:20 PM
ericread   Great job at finally correcting this buggar! ...   Jun 16 2008, 12:01 PM
Tab914   Just took it out for a short ride last night after...   Jun 16 2008, 01:27 PM
swl   Wow! Great catch Dominic! I can see why yo...   Jun 16 2008, 06:54 PM
Tab914   Steve, Wishfull thinking I know. :lol: Yeah th...   Jun 17 2008, 07:06 AM
iamchappy   Im glad you you solved it, i was going to suggest ...   Jun 17 2008, 07:42 AM
swl   It will be a while before I'm cruising. The O...   Jun 18 2008, 05:38 PM
Tab914   Excellent, That sounds good. Would be fun to get ...   Jun 20 2008, 09:06 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:02 PM
