| Lavanaut |
Jun 11 2008, 12:52 PM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
After a good amount of info from all sorts of people in response to this thread, I went back and skimmed what I could wrap my head around. Here's what I've come up with (slowly adding links to pics as I have time):
Items in green are the most-recently added. Items in red have been recently updated/changed due to new information. Cowl-to-Fender Seam: absent (metal-filled) or empty for very early 70 (up to #49), rubber seam thereafter. (IMG:style_emoticons/default/confused24.gif) Ignition Switch: on dash, left of column for 70 & 71, on right side of column for 72 Interior Mirror: small version for 70 and 71, larger for 72 Dash Top: wide opening for glovebox for 70 & 71, narrower for 72 (to accommodate dash vents) Dash Vents: Absent for 70 & 71, present for 72 Door Panels: smooth vinyl for 70 & 71, basketweave for 72 Glove Box: wide for 70 & 71, narrow for 72 (to accommodate dash vents) Main Wiring Harness: hybrid /4-/6 harness for 72 cars Passenger Foot Rest ("dogbone"): present in 70 & 71, replaced with foam pad on bulkhead for 72 cars Passenger Seat: fixed for 70 & 71, moveable for 72 Rear Bumper: squared off for 70 and early 71, rounded for later 71 and 72 Seat Inserts: smooth vinyl for 71, basketweave for 70 & 72 Seatbelts: non-retractable for all years Steering Column: /4 steering column for 72 cars If you know of further differences, please post to this thread and I'll include them in this list. Please include a picture if you can and I'll link to it from here. And thanks to everyone who's contributed! (IMG:style_emoticons/default/beerchug.gif) Reid This post has been edited by Lavanaut: Oct 15 2008, 07:07 PM |
| Heeltoe914 |
Jun 11 2008, 06:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
There's some misinformation here. Check your facts before posting. 70-71 had non-retractable seatbelts. 70-71 had non moveable passenger seat. 70-71 had 911 style ignition switch. All 914's had the seam at the fender/cowl. 72 914/6 was pretty much a /4 with a 6/ motor & suspension on it. 70-71 had a different rear bumper. The lic plate area edges have sharp corners. Almost all correct: 72 914/6 was pretty much a /4 with a 6/ motor & suspension on it. This is not true as I seem to understand it 72 914 6s are no more than left over 71s that did not sale. Thier is no motor mount under the longs for the bar that is used on the 4s the 6s where mounted to the firewall. look for oil tank in the Driverside fender. All 6s had 5 lugs. from the factory. The hood badge you see on some 6s was added by the dealer more so than by the factory. |
| SirAndy |
Jun 11 2008, 06:45 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
as I seem to understand it 72 914 6s are no more than left over 71s that did not sale. not quite. '72 /6s have the /4 steering column and the /4 main wire harness. there was an adapter to the /6 relay board on those cars. and at least one of the 916s (which basically were '72 914/6) was build on a modified /4 chassis ... (IMG:style_emoticons/default/shades.gif) Andy |
Lavanaut 914-6: Differences from year to year Jun 11 2008, 12:52 PM
Root_Werks I know a couple simple ones like, 69-70 no pass mo... Jun 11 2008, 12:55 PM
6freak
I know a couple simple ones like, 69-70 no pass m... Jun 11 2008, 01:36 PM
Phoenix 914-6GT
I know a couple simple ones like, 69-70 no pass ... Jun 11 2008, 01:38 PM
ericread Did you check Jeff Bowlsby's site? It seems t... Jun 11 2008, 12:59 PM
Phoenix 914-6GT 70-71 has the 911 style ignition switch. 72 has an... Jun 11 2008, 12:59 PM
GeorgeRud Early cars had a finished cowl to fender seam, no ... Jun 11 2008, 02:06 PM
6freak
Early cars had a finished cowl to fender seam, no... Jun 11 2008, 02:19 PM
Early cars had a finished cowl to fender seam, no... Jun 11 2008, 03:03 PM
davep
Early cars had a finished cowl to fender seam, n... Jun 11 2008, 03:57 PM
George is correct. Quoting from the factory bulle... Jun 11 2008, 05:44 PM
burton73
[quote name='SirAndy' post='1043802' date='Jun 11... Jun 12 2008, 12:53 PM
It is very clear that my car 9140430041 has fende... Jun 12 2008, 01:09 PM
gms
[quote name='davep' post='1043825' date='Jun 11 2... Sep 1 2008, 04:39 PM
gms here is #41 marked up Sep 1 2008, 04:44 PM
gms Here is 914.043.0035 it had a filled seam Sep 1 2008, 04:46 PM
Lavanaut
I have attached 2 photo the red one is 914.043.00... Sep 3 2008, 07:00 PM
smontanaro Also the rear view mirror (interior) is tiny in th... Sep 3 2008, 09:17 PM
Lavanaut
Got dimensions for "tiny" and not tiny?... Sep 3 2008, 11:23 PM
gms
I have attached 2 photo the red one is 914.043.0... Sep 3 2008, 10:57 PM
Jeffs9146
Early meaning 69? :confused: Jun 11 2008, 02:15 PM
McMark The seam is the line on either side, running from ... Jun 11 2008, 02:28 PM
6freak
The seam is the line on either side, running from... Jun 11 2008, 02:32 PM
Lavanaut This is great info guys ~ keep it coming and I wil... Jun 11 2008, 02:35 PM
Jeffs9146 I have never seen one that was not done by the own... Jun 11 2008, 02:36 PM
markb There's some misinformation here. Check your f... Jun 11 2008, 02:44 PM
ericread Sorry, in my earlier post I failed to include the ... Jun 11 2008, 02:45 PM
6freak
Sorry, in my earlier post I failed to include the... Jun 11 2008, 03:02 PM
ericread
[quote name='ericread' post='1043794' date='Jun 1... Jun 11 2008, 03:14 PM
Jeffs9146
That's what I thought but only from my exper... Jun 11 2008, 02:47 PM
Lavanaut
There's some misinformation here. Check your ... Jun 11 2008, 03:00 PM
Does a thread like this already exist? I did che... Jun 11 2008, 03:01 PM
Lavanaut
apparently, you didn't look very hard ... :r... Jun 11 2008, 03:23 PM
That's a /4 vs. /6 list....is it not?
it sur... Jun 11 2008, 03:30 PM
Lavanaut
it sure is, it's got info on all the things d... Jun 11 2008, 03:38 PM
It seems you disagree...
nope ... just trying to... Jun 11 2008, 03:51 PM
Lavanaut
It seems you like to lean back and let others do ... Jun 11 2008, 04:05 PM
Did I manage to piss you off somehow?
jeeze, step... Jun 11 2008, 05:47 PM
Lavanaut Thanks Dave. For the record, when talking about S... Jun 11 2008, 04:09 PM
Lavanaut Fair enough.
My intention was (is) to extract t... Jun 11 2008, 05:56 PM
Pat Garvey
Does a thread like this already exist? I did che... Jun 11 2008, 08:38 PM
Phoenix 914-6GT
Does a thread like this already exist? I did ch... Jun 11 2008, 09:46 PM
Lavanaut
You should have posted your questions there, not ... Jun 11 2008, 10:14 PM
lagunero
Anyone else out there wanna break my balls for s... Jun 12 2008, 01:17 AM
6freak
Anyone else out there wanna break my balls for ... Jun 12 2008, 10:27 AM
Gustl
[...] put togather with whatever Porsche had on t... Jun 12 2008, 11:38 AM
ericread Boy, I was in a really shitty mood today. Bad hea... Jun 11 2008, 10:07 PM
carr914 Jeez, you old timers need to lighten up. Reid aske... Jun 11 2008, 10:13 PM
Lavanaut So if I'm not mistaken, the interior of the ... Jun 11 2008, 10:20 PM
Gustl
So if I'm not mistaken, the interior of the ... Jun 11 2008, 11:37 PM
smontanaro only the MY'71 cars had the very-similar-to-re... Jun 12 2008, 12:14 PM
Gustl
So you're saying that the basket weave door p... Jun 12 2008, 12:27 PM
Gustl
So you're saying that the basket weave door p... Jun 12 2008, 12:35 PM
mel reckling
So if I'm not mistaken, the interior of the ... Jun 12 2008, 01:23 PM
Phoenix 914-6GT :chair: I'll bust your balls :evilgrin:
We... Jun 11 2008, 10:22 PM
Lavanaut
You going to come up to the WCR?
Oh how I wish I... Jun 11 2008, 10:37 PM
Lavanaut Ahhhh...nice Gustl, thanks. This should probably ... Jun 11 2008, 11:44 PM
Eric_Shea MY08 - 3.6 engines Jun 12 2008, 12:30 PM
Eric_Shea My MY70 - smooth finish on the door panels.
Pic... Jun 12 2008, 12:34 PM
Lavanaut
Pick me! Pick me! Pick me! You... Jun 12 2008, 12:45 PM
Gustl
Thought I'd read elsewhere that they were bas... Jun 12 2008, 01:46 PM
Gustl
MY'70 - smooth surface
MY'71 - smooth sur... Jun 13 2008, 08:36 AM
6freak
[quote name='Lavanaut' post='1044168' date='Jun 1... Jun 13 2008, 08:47 AM
Lavanaut MY'70 seat inlays (only in colour of trim)
- ... Jun 13 2008, 03:43 PM
Gustl
So which year would these be? I believe them to ... Jun 13 2008, 05:29 PM
Lavanaut this looks like the MY'71 "leatherette pe... Jun 13 2008, 05:51 PM
Gustl
Ok, making sense to me now Gustl, you're a pa... Jun 14 2008, 05:57 AM
Eric_Shea
#11 is w/o the seam. Jun 12 2008, 06:01 PM
got a picture of that?
... Jun 13 2008, 12:15 PM
Eric_Shea Yes Sir but for some reason he doesn't want th... Jun 13 2008, 03:33 PM
GeorgeRud I seemed to start quite a discussion when I mentio... Jun 13 2008, 05:46 PM
Dave_Darling Rats, I wish I could remember a source. I thought... Jun 14 2008, 12:17 AM
Thus not helping the confusion in any way whatsoe... Jun 14 2008, 12:33 AM
Eric_Shea
Agree... just spent a lot of time with the mop a... Jun 14 2008, 02:11 PM
Phoenix 914-6GT Good think I don't believe in carma or Karma :... Jun 14 2008, 02:27 PM
Gustl
How about the 916s. They are sixes too right :D
... Jun 14 2008, 02:51 PM
Phoenix 914-6GT Thanks Wolfgang
Any info on the Engines that came... Jun 14 2008, 02:59 PM
Lavanaut [woof]
Nicely done Eric, thanks. :thumbsup:
Jon,... Jun 14 2008, 03:56 PM
Phoenix 914-6GT
[woof]
Jon... Jun 14 2008, 04:24 PM
Gustl
One thing I've always been curious about was ... Jun 14 2008, 04:40 PM
carr914 My carrma ran oer your dogma :D
T.C. Jun 14 2008, 04:24 PM
Phoenix 914-6GT I really want one of those 914-6-VW-PORSCHE badges... Jun 14 2008, 04:55 PM
carr914 Auto Atlanta has them in stock I think Jun 14 2008, 04:57 PM
Phoenix 914-6GT
Really? :... Jun 14 2008, 05:24 PM
carr914 Jon, Page 118 of their catalog. Item G914 559 112 ... Jun 14 2008, 06:38 PM
Phoenix 914-6GT Sounds good to me T.C. Let me know. Jun 15 2008, 12:01 AM
Lavanaut Thanks to Rusty for moving this topic to the origi... Sep 9 2008, 06:44 PM
sixerdon
After a good amount of info from all sorts of pe... Sep 13 2008, 08:42 PM
Lavanaut
Reid,
I totally missed your ensemble of differenc... Sep 18 2008, 11:42 AM
Lavanaut Mel has confirmed that the seatbelts in his '7... Oct 15 2008, 07:04 PM
mel reckling Here's a shot, sorry it came out so bad.
:dr... Oct 15 2008, 07:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
