Brazing: How do you get rid of it?, on the trunk pivot... |
swood |
Jan 2 2004, 04:51 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I'm having a tough time removing the pivots. How do you get rid of the brazing? I found more of it used in the trunk to fill a small rust hole.
I don't want to grind too much in case I cut through the sheet metal, and the grinder wheel (4.5") is too big to get the rear side. Suggestions? Attached image(s) |
Mueller |
Jan 2 2004, 06:14 PM
If you don't want to grind, you'll have to melt it with a small torch using MAP gas. Propane might work, but you'l find more uses with the hotter MAP gas.
Lo-Fi Version | Time is now: 7th June 2024 - 05:10 AM |
