| Tab914 |
Jun 9 2008, 11:21 PM
Member ![]() ![]() Group: Members Posts: 159 Joined: 25-April 04 From: Alexandria, Ontario, Canada Member No.: 1,978 Region Association: Canada |
Hello all,
Well took the teener out today to start my summer driving. Charged the battery and car started on first cranks. Let the car run for a bit, turned it off and turned it back on. Pulled out of the garage and took pictures to get a new insurance policy and let the car sit for half an hour. Here is where the fun begins. Go to start the car to put it back in the garage and......nothing. Don't hear the fuel pump buzz when I turn the key. Push the car back in the garage and start testing. The car is a 1974, 2.0lt d-jet. Direct power to the pump shows that pump works. Jumping the relay shows that power from the relay board will reach pump. When pump is running while jumping the relay, the car cranks but won't start. Then, when checking the main power relay, looks like I am getting no power to the relay board. Swaped out the computer (brain) for another and still no power to the relay board. Tried jumping the wires at the relay under the passenger seat and still nothing. Been going over and over the electrical diagrams and getting nowhere. Got tired and can't think anymore. Very frustrating after having the car start right off the first crank. Is there something simple I am not thinking of? Thanks in advance to whoever can help. Appreciate all answers / suggestions. Will check tomorrow after a nights sleep. Cheers, Dominic. (IMG:style_emoticons/default/beer3.gif) |
| roadster fan |
Jun 12 2008, 10:02 PM
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Well, I had this same problem on my 71 a while back. Pump stopped working, went thru all the trouble shooting stuff, cleaned and the connections, worked great....................for about 3 miles then died about 1/4 mile from my house.
I narrowed the problem down to the same ECU circuit that connnects on the relay board at pin III also. Swapped the ECU for another after determining all the wiring was good and reading Brad Anders' info about how the circuit works on the ECU. Fuel pump circuit worked for 2 days and then crapped out again. I opened up the first ECU and started tracing the fuel pump circuit on the board and found a transistor that had three corroded legs and one was broken. I will take pictures and post later. I am trying to source a replacement transistor as the broken leg appears to be the cause of the intermittent problem. It doesnt totally fail, but due to vibration will fail, then if you unmount the ECU and check the cables it will make a connection and you think you fixed the problem only to have it happen again after you run the car for a while. Frustrating problem so I bypassed the ECU fuel pump circuit, and have the pump run whenever the ignition is on. I ran a wire from pin III to the ground point near the relay board below the drivers side sail. I used a small screwdriver to remove the spade terminal in the white plug from the ECU. I will post a pick of this as well. This works good, I know some will say that if the car is involved in an accident and the engine stops that the pump will continue to pump fuel creating a fire hazard but really you just need to shut the ignition off to stop the pump. When I find the replacement part I will fix the two ECU's and go back to the stock setup. When you see the picks of the transistor you will see why and how they fail. Whew, sorry for the long post but I hope it helps you with your problem. Photos to follow in a little while. Jim |
Tab914 Fuel pump issues Jun 9 2008, 11:21 PM
SirAndy try swapping the relay for one of the headlight re... Jun 9 2008, 11:50 PM
ejm
This power comes to the board thru one of the re... Jun 10 2008, 05:27 AM
Tab914 Hey Andy,
Thansk for the reply. I tried that firs... Jun 10 2008, 08:54 AM
ericread A couple of ideas:
1. Are you sure the fuel pump i... Jun 10 2008, 09:03 AM
Dave_Darling A couple of resources for you--
Text troubleshoot... Jun 10 2008, 09:32 AM
Tab914 Hey Eric,
Did that as well and that did show me t... Jun 10 2008, 09:34 AM
Tab914 Dave,
Wow.
A lot of info in there.
Haven't... Jun 10 2008, 09:57 AM
dbgriffith75
Okay, I'm not 100% sure on where all power f... Jun 10 2008, 11:22 AM
wertygrog hmm...my fuel pump stopped working a few days ago.... Jun 10 2008, 10:13 PM
ericread WOW! Dave Darling's stuff is amazing... Jun 11 2008, 08:35 AM
Dave_Darling You mean Bill Williams' article, and the amazi... Jun 11 2008, 09:37 AM
Tab914 Well the flow charts are great. From isolating the... Jun 11 2008, 11:26 AM
ericread Glad to hear you're mobile again! :drivin... Jun 11 2008, 02:55 PM
swl Dominic,
Pin III is not exactly a ground point. T... Jun 12 2008, 08:26 PM
Tab914 Thanks Steve.
Good to see a fellow canuck replyin... Jun 12 2008, 09:41 PM
roadster fan The following pics are of the 015 ecu and relay bo... Jun 12 2008, 11:28 PM
roadster fan Oh, forgot the transistor pic
and the pic of ... Jun 12 2008, 11:33 PM
swl Intermittent can be a beast. If you can catch it ... Jun 13 2008, 05:49 AM
Tab914 Jim,
Wow, nice post. Thanks for the pics and the ... Jun 13 2008, 09:34 AM
swl Hey Dominic, I just went over your other post abou... Jun 13 2008, 04:31 PM
Tab914 Hey Steve,
Going out to the garage now to try and... Jun 15 2008, 09:17 AM
Tab914 Well after being at it all day I finally got the c... Jun 15 2008, 10:20 PM
ericread Great job at finally correcting this buggar! ... Jun 16 2008, 12:01 PM
Tab914 Just took it out for a short ride last night after... Jun 16 2008, 01:27 PM
swl Wow! Great catch Dominic! I can see why yo... Jun 16 2008, 06:54 PM
Tab914 Steve,
Wishfull thinking I know. :lol:
Yeah th... Jun 17 2008, 07:06 AM
iamchappy Im glad you you solved it, i was going to suggest ... Jun 17 2008, 07:42 AM
swl It will be a while before I'm cruising. The O... Jun 18 2008, 05:38 PM
Tab914 Excellent,
That sounds good. Would be fun to get ... Jun 20 2008, 09:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:07 PM |
